Windshield wiper fluid
Results 1 to 8 of 8
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Windshield wiper fluid in Cadillac Escalade Forums; I was driving my 2007 escalade and noticed that my rear windshield does not spray fluid the wipers work both ...
    xlraw is offline Cadillac Owners Member
    Oct 2011
    73
    I was driving my 2007 escalade and noticed that my rear windshield does not spray fluid the wipers work both front and back and sprays in the front. I hope this is not a problem with the pump. Does anyone have any suggestions.
    Thanks
    48Dodge is offline Cadillac Owners Fanatic
    Automobile(s): '08 Escalade ESV
    Mar 2011
    41
    442
    Is it pouring on the ground anywhere? If so, there are usually a couple connections along the line to check. If not, then check the pump at the reservoir. May have a bad connection or may need to replace the motor.
    Sent from my ADR6300 using Tapatalk
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,307
    Re: Windshield wiper fluid
    Some times it takes a while to come thru, I know the 07' I just purchased must have took a minute of pushing the washer button before fluid came out, I was about to start checking it out when it started flowing, I could hear the pump working
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,722
    I agree with hcvone, sometimes it does take it a while, try pushing the washer button for a little longer. If that does not work I would recommend taking it to your local dealer to have them diagnose and/or repair the issue for you. Let us know what you find out.
    Breanne
    Oct 2011
    73
    Apparently the fuse for the rear washer keeps blowing everytime I push the button so I will take it to the dealership and let you know what they find.
    Cyberman is offline Cadillac Owners Member
    Automobile(s): 2007 Escalade ESV
    Jul 2011
    31
    Quote Originally Posted by 48Dodge View Post
    mine is leaking/gushing on the ground right behind the front driver-side wheel, what connections am i looking for? do i need to get under the car? someone please explain
    dknieriem is offline Cadillac Owners Member
    Jan 2014
    1
    I had the same issue. The rear hose starts at the reservoir and then goes up along the hood...and eventually snakes down. Mine was disconnected along the drivers side hood...right in about the middle of the front quarter panel. There was not a lot of slack in the line...and must have pushed out when the line froze with this cold weather.
    2kflhr's Avatar
    2kflhr is offline Cadillac Owners Enthusiast
    Automobile(s): '10 Escalade, '97 Eldo ETC (Z)
    Dec 2004
    Mooresville, NC
    58
    918
    I'm not sure about the Escalade but I had a Yukon once that when the washer fluid level got to a low point it would continue to pump fluid the front wipers but would not the rear.
  11. Remove Advertisements
