Replace Brake Rotors vs. Machining Brake Rotors
Results 1 to 7 of 7
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Replace Brake Rotors vs. Machining Brake Rotors in Cadillac Escalade Forums; I've had some noise coming from one of my wheels and my dealer said that they can fix the issue ...
    fivepix's Avatar
    fivepix is offline Cadillac Owners Fanatic
    Automobile(s): '11 Cadillac Escalade
    Aug 2008
    NA
    337
    I've had some noise coming from one of my wheels and my dealer said that they can fix the issue by machining the rotors but I've been told by a few people that it's just best to replace them with new rotors.
    I run 24's in the summer and I think if I get the rotors machined I'll just end up having to replace them anyways I know the OEM rotors aren't the best to begin with I've been looking around on the forum and it looks like there are a few options out there, defiantly not looking Brembo price do you guys suggest a particular brand? what should I avoid?
    Looking at these at the moment:
    http://ebcrotors.com/p-223-ebc-sport-rotors.aspx
    Anyone have these? - Premium Dimpled and Slotted Brake Rotors
    http://brakeperformance.com/brake-ro...ake-Rotors.php
    MrHolland's Avatar
    MrHolland is offline Super Moderator
    Automobile(s): 2010 Platinum Escalade, 1996 Fleetwood Brougham
    Jul 2010
    Midwest
    5,672
    Re: Replace Brake Rotors vs. Machining Brake Rotors
    I dont like to turn rotors because they just warp again, easier and sooner than before. Someone in here purchased those rotors but last I saw they hadn't installed them. I wish someone would try them and give their opinion.
    Found the thread
    http://www.cadillacforums.com/forums...rformance.html
    luxurylife33's Avatar
    luxurylife33 is offline Cadillac Owners Connoisseur
    Automobile(s): 99 Escalade (sold) 03 Escalade EXT (sold) - 07 Escalade EXT
    Oct 2008
    Long Island
    29
    1,363
    get new ones.... resurfacing them almost never lasts
    quattrotman's Avatar
    quattrotman is offline Cadillac Owners Fanatic
    Automobile(s): 07 Escalade EXT
    Jul 2011
    Vancouver BC
    46
    357
    Rotors for our trucks are cheap enough, I personally don't think it worth machining them. Labour is the biggest cost to consider here so if you're getting it done, mind as well put in new parts.
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,291
    With the price of new rotors being pretty cheap our shop stopped turning them, because bad rotors do not get better by turning them, the problem will come back sooner because the warp in from heat and you are not getting rid of that. Your rotors are warpping from running 24's and the heat they cause, depending on where you live and drive you may need big brakes i.e. a lot of hills, or you will be having this issue no matter what aftermarket rotors you run.
    fivepix's Avatar
    Aug 2008
    NA
    337
    Is the EBC rotors a good brand? any experience with these? Are they the same or better/worse than OEM?
    Apr 2003
    13,291
    Quote Originally Posted by fivepix View Post
    Our shop pretty much uses EBC rotors and pads (I believe the yellow for Escalade, but I will confirm that) and they stop better than stock, but do produce a little "grind" noise but no squeal, I am going to put a set of them on my new/old 07' I just picked up
  10. Remove Advertisements
