Results 1 to 8 of 8
Thread: 07 Escalade Brakes
    bigtone1013's Avatar
    bigtone1013 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Escalade
    Nov 2011
    308
    07 Escalade Brakes
    I have a 2007 escalade and I love it however the brakes have seized up twice first the right then the left the dealership replaced the rotors and calipers and brakes. I bought the car used and I was thinking that maybe a complete inspection wasn't done before it was sold to me, but sometimes I feel that the brakes engage still I was wondering if anyone else was having this problem if so how can it be fixed.
    JimmyH is offline Cadillac Owners 10000+ Posts
    Dec 2006
    42
    37,299
    Re: 07 Escalade Brakes
    copying thread to escalade so you can get answers there
    MrHolland's Avatar
    MrHolland is online now Super Moderator
    Automobile(s): 2010 Platinum Escalade, 1996 Fleetwood Brougham
    Jul 2010
    Midwest
    5,683
    Could be brake hoses, although I would think the dealer would catch that.
  5. #4
    Nov 2011
    308
    Quote Originally Posted by mrholland View Post
    I am far from a mechanic but why would the brake hoses cause the brakes to engage.
  6. #5
    quattrotman's Avatar
    quattrotman is offline Cadillac Owners Fanatic
    Automobile(s): 07 Escalade EXT
    Jul 2011
    Vancouver BC
    46
    357
    If they are 'seizing' then my guess would be the calipers need rebuilding/replacing. If rusty, the piston can seize and cause brakes to lock up. Doing the rotors and pads will do nothing to alleviate this.
  7. #6
    MrHolland's Avatar
    Jul 2010
    Midwest
    5,683
    Absolutely, hoses fail from the inside. As they deteriorate and come apart from the inside they can swell or become plugged up. The flow will be allowed to move from the master cylinder to the caliper but not the other direction which can keep the brakes engaged. The excessive heat generated from this condition can cause the caliper to fail. In most cases you cant look at a hose and see an internal failure. Just a thought not necessarily a diagnosis. Good luck.
  8. #7
    Nov 2011
    308
    Quote Originally Posted by quattrotman View Post
    The calipers were replaced but it seems and I could be just paranoid to still be engaging at times.
  9. #8
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,299
    Even brake fluid need replacing, that may have caused the issues that caused the rotors to "bind", just the unknown of used cars/trucks, you have to assume the owner before you did nothing.
  • You may not post replies
