Trans Fluid Change Tips?
Results 1 to 9 of 9
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Trans Fluid Change Tips? in Cadillac Escalade Forums; Anyone come up with a less messy procedure for changing the tranny fluid than dropping the pan while still full ...
    a016738 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Aug 2007
    22
    Anyone come up with a less messy procedure for changing the tranny fluid than dropping the pan while still full of fluid?
    I'll never understand why so few vehicles come with drain bolts...just makes no sense at all. And no drain on the rear diff?
    -John
    '07 EXT
    MrHolland's Avatar
    MrHolland is online now Super Moderator
    Automobile(s): 2010 Platinum Escalade, 1996 Fleetwood Brougham
    Jul 2010
    Midwest
    5,683
    Re: Tranny Fluid Chg Tips?
    On most of my cars I have fashioned a brass "T" fitting on one of the transmission coolant lines. This allows me to open the "T" fitting with the engine running to pump the fluid out of the transmission while pouring fresh fluid in the top side of the transmission. I would recommend having everything set up in order to keep a constant flow of fluid moving through the transmission. If the system holds 12qts ill pour 10qts in it while its being pumped out of the bottom, shut the car of, close the "T" fitting and use the remaining 2qts to top it off. Its not an exact science but does seem to work pretty well. Good luck!!
    luxurylife33's Avatar
    luxurylife33 is offline Cadillac Owners Connoisseur
    Automobile(s): 99 Escalade (sold) 03 Escalade EXT (sold) - 07 Escalade EXT
    Oct 2008
    Long Island
    29
    1,363
    http://www.cadillacforums.com/forums...id-change.html
    Did this on my 03 escalade and worked perfect!
    MrHolland's Avatar
    Jul 2010
    Midwest
    5,683
    Thats the same basic concept I use except the fitting is actually plumbed into the line and has a cap on the end. Here is a pic to give you an idea.
    K9Caddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 AWD Escalade Ultra Luxury Raven Black
    Oct 2009
    Illinois
    38
    1,493
    Re: Trans Fluid Change Tips?
    Another way of doing it using a fluid extractor. Drop a line in the dipstick tube and suck out the tranny fluid. Drop the pan and change the filter. No need for a valve or the risk of having a leak. Just suck it out every 10-15 miles and you will never need a flush. Here is an example:
    http://www.amazon.com/Mityvac-7400-L...d_sim_sbs_sg_1
    Aug 2007
    22
    Hey, that's an idea...anyone else use this method or have an argument against it?
    Looking to replace with synthetic fluid and running through 15 quarts of that stuff using the flush method seems wasteful as I'll be throwing a good amount of it right out through the drain pan to get the old stuff out.
    On the other hand, using the pump and drain method doesn't get it all out either right? Always the stuff in the torque converter the you can't drain or suck?
    Guess a flush is really the only way to get it ALL changed out?
    -John
    '07 EXT
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,299
    Put a drain in the stock pan when you change the fluid, next time it's there
    MrHolland's Avatar
    Jul 2010
    Midwest
    5,683
    Quote Originally Posted by a016738 View Post
    -John
    '07 EXT
    It probably is wasteful, but it seems to be an effective way for ME to change the fluid. I would imagine a transmission flush machine would do the same thing with or without starting the car. You are correct in saying that you cant get all the fluid out of the torque converter, it'll always be half full, (half empty if you're a pessimist) but I'm satisfied by flushing it. A couple of cases of trans fluid is much cheaper than a trans rebuild!!
    Aug 2007
    22
    Quote Originally Posted by mrholland View Post
    True...and I'm not doing it that often. I guess the flush really is the right way to do it.
    Thanks to all for the suggestions and responses.
    -John
    '07 EXT
  12. Remove Advertisements
