2008 Escalade Rattle driver side front end
Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By 2007XTSDub
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, 2008 Escalade Rattle driver side front end in Cadillac Escalade Forums; Yesterday my 2008 Escalade was at the Cadillac dealer for the whole day. It has a subtle quiet raddle in ...
    bfrangakis is offline Cadillac Owners Member
    Automobile(s): 2008 Escalade
    Nov 2011
    53
    6
    Yesterday my 2008 Escalade was at the Cadillac dealer for the whole day. It has a subtle quiet raddle in the front end drivers side. Seems to be at slower speeds only and while going over bumps. You can even hear it when you drive off the driveway onto the street. The dealer said they checked the entire front end/suspension/etc. greased and lubed all parts. I drove off the lot and heard the noise again.
    It had new front tires installed 7 months ago. Also the hood was replaced a year ago due to a baseball landing on it at a ball park. Any thoughts on solving this frustraiting noice on my black beauty?
    luxurylife33's Avatar
    luxurylife33 is offline Cadillac Owners Connoisseur
    Automobile(s): 99 Escalade (sold) 03 Escalade EXT (sold) - 07 Escalade EXT
    Oct 2008
    Long Island
    29
    1,363
    Re: 2008 Escalade Rattle driver side front end
    check the bolts holding the hood down.. maybe the body shop didnt tighten them enough? It really could be anything... just jack it up and start tugging on everything
    hdmech is offline Cadillac Owners Member
    Automobile(s): 2007 escalade , 87 GN
    Apr 2010
    Toronto
    55
    38
    murphy's Avatar
    murphy is offline Cadillac Owners Enthusiast
    Automobile(s): 2009 Cadillac Escalade Platinum
    Dec 2008
    Alberta,Canada
    813
    Check the wheel center cap..they usually rattle
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,299
    Quote Originally Posted by murphy View Post
    What he said, these have caused more rattles for owners than anything
    Big Windy Ext's Avatar
    Big Windy Ext is offline Cadillac Owners Enthusiast
    Automobile(s): Caddy EXT
    Aug 2009
    Downers Grove Il
    633
    It took three visits and a service writer a ride home before they replaced my front shock.I also had a TSB about the hood hinge passenger side done,another difficult find that I found because there was a bit of worn paint.I hate annoying rattles!!
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,711
    I agree, check the wheel center cap. I have heard that a few owners have had this issue. Let us know what you find out.
    Breanne
    Nov 2011
    53
    6
    Thank you for the response....was hoping it was that easy but they are all tight
    Nov 2011
    53
    6
    did that and all 4 seem in tact and show no signs of rattling
    Nov 2011
    53
    6
    I am sure its the strut or a shock but the dealer claims its not. How do they know if the strut is good or if the shock is good or bad? Why would it rattle?
    Nov 2011
    53
    6
    Centre Caps are all ok...its very disapointing after the large amount of money this vehicle cost and the dealer has no idea what it is. Also, all of the problems are starting 1000 miles after the bumper to bumper is done
    2007XTSDub's Avatar
    2007XTSDub is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 EXT
    Jul 2010
    504
    Thats why you get rid of these when your up!
    Andrew224 likes this.
    Jake123 is offline Cadillac Owners Member
    Dec 2013
    1
    Quote Originally Posted by bfrangakis View Post
    Try your plastic door locks inside your escalade they tend to rattle a lot. You can easily fix this by unlocking the doors so the plastic door lock pins are up and pull the tab open at the bottom of the pin and lift the plastic cover off. Now you insert a small piece off soft Velcro on door panel and put plastic door pin back on and it's rattle free
  16. #14
    packman01's Avatar
    packman01 is offline Cadillac Owners Member
    Automobile(s): 2007 escalade ext
    Jan 2012
    37
    79
    Had the same issue, their is a washer/cap on top of the strut under the boot. It can come loose and rattle over bumps at slow speed.. Can't hear it at high speed... If you take your wheel off you can fit your fingers under the boot and check... I cut a small piece of rubber and put it between the strut and washer to isolate it till I got new shocks ...
  17. #15
    Andrew224's Avatar
    Andrew224 is offline Cadillac Owners Fanatic
    Automobile(s): '41 67, '66 75, '02 Deville-L, DTS, DTS-L, XTS, '08 Escalade
    Apr 2012
    Plainfield, IL
    37
    132
    I just fixed a rattle on my '08. As stupid as it sounds, it was the front license plate. I only had the two top screws holding it on. The bottom of the plate would slightly rattle (where I could hear it at least) when my truck went over bumps at low speeds. I secured the bottom of the plate with two more screws and the rattle was fixed.
  18. Remove Advertisements
