Nav radio reboots, airbag light blinks and stabilitrak message while driving - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 29 of 29
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Nav radio reboots, airbag light blinks and stabilitrak message while driving in Cadillac Escalade Forums; Hey guys I had the exact same issue in my 07. I took it to the dealer ( Cadillac of ...
  1. #16
    bignate3rd is offline Cadillac Owners Member
    Automobile(s): '07 Escalade AWD
    Aug 2007
    Atlanta, GA
    6
    Re: Nav radio reboots, airbag light blinks and stabilitrak message while driving
    Hey guys I had the exact same issue in my 07. I took it to the dealer ( Cadillac of Metairie on Lime) no problem found. He stated he'd tightened all of the grounds on the truck. I left the dealer and drove to Atlanta where I'm living now and the problem reared it's ugly head again. So I pulled over to a gas station and shut the truck off only to have it go completely dead. I wiggled the cable that is connected to the negative battery terminal and power was restored. I also noticed some exposed wire where the cable was plugged into the negative battery terminal.
    So I decided to cut off the old negative battery terminal, restrip the two wires (one large gauge and one smaller gauged wire), and install a new negative battery terminal. It has been over 3 weeks and I have not had any other issues with the truck since replacing the negative terminal. I'm not sure if this would fix anyone elses, but it's worth taking a look at.
    I'll keep you guys posted...
  2. #17
    hdmech is offline Cadillac Owners Member
    Automobile(s): 2007 escalade , 87 GN
    Apr 2010
    Toronto
    55
    38
    Mountaincaddy my 07 does the exact same thing as you described in your post, any luck resolving it ?
  3. #18
    mountaincaddy is offline Cadillac Owners Member
    Automobile(s): 07 Escalade ESV
    Feb 2009
    Los Angeles
    11
    I think so.
    I brought the ESV back in a few weeks ago after it would not turn over - completely dead, but after 10 min it would start right up.
    The dealer finally did some research on this and they pinpointed the problem to the battery cables. As this problem was manifesting in other Tahoes/Suburbans as well.
    They did not change the cables, what they did was drill a hole on the + terminal block(where the two red cables merge/are crimped) and filled it up with solder/weld - to eliminate any loose connections which would result in a drop in voltage to the electrical system. If the electrical system doesn't have sufficient voltage, you'll see all kinds of weird things happening.
    I don't think they did anything to the - cable as it looked untouched. I also had them replace the mega fuse on the firewall.
    So far, after 2+ weeks, I haven't had a problem, however this was an intermittent issue, so it may come back. But I really do believe the cables are the problem.
  5. #19
    Feb 2009
    Los Angeles
    11
    Actually it was the battery cable terminals not properly crimping the cables and securing them. In my case it was the + terminal, in others it was the - terminal.
  6. #20
    Apr 2010
    Toronto
    55
    38
    Thanks for your response. I will look closely at mine
  7. #21
    99ssconv is offline Cadillac Technician
    Automobile(s): CTS Vsport
    Sep 2011
    155
    a 2 minute test with a good volt meter and performing a voltage drop across the negative and positive battery cables. Remove both fuel injector
    fuses, one end of the meter goes on the battery negative cable, the other lead goes to the end of the negative cable where it mounts to the
    engine block. Crank the engine over and anything more than 200mv is out of spec. Replace the cable, Do the same test on the positive battery
    cable going from the positive post and the other lead at the underhood fuse block, there are 2 studs at the front, Attach the other lead to one
    of the studs and crank the engine. 200mv or less is a good cable.
  8. #22
    gabe8496's Avatar
    gabe8496 is offline Cadillac Owners Fanatic
    Automobile(s): 2008 Cadillac Escalade ESV
    Oct 2008
    Los Fresnos
    36
    136
    Quote Originally Posted by 99ssconv View Post
    Which are the injector fuses? I'm having similar issues and just right now when I shut off my ESV the power went completely out. No dome lights, chime, etc. About 5mins passed and just happened to click the unlock button the key fob and it unlocked. Now I got 12+ back again....
  9. #23
    gabe8496's Avatar
    Oct 2008
    Los Fresnos
    36
    136
    I removed the cables for about 15mins, cleaned up the terminal posts and the terminals on the cables and reconnected everything ensuring a good tight connection. So far everything is working great. Will post some updates in a few days.
  10. #24
    duranguense's Avatar
    duranguense is offline Cadillac Owners Member
    Automobile(s): 2008 Escalade EXT
    Sep 2012
    Odessa, TX
    3
    I have a 2008 EXT and I am having this same issue like described in the first post. After reading through every post was just wondering if the issue is best related to the cables. Any follow ups from previous post that could help me before I start first with the cables/terminals.
  11. #25
    Sep 2012
    Odessa, TX
    3
    Update: I had a bad ground cable connection from the cable to the battery terminal (not tight enough) causing voltage loss. Got that adjusted and been driving it a couple days now and no problem.
  12. #26
    brianbigb03 is offline Cadillac Owners Member
    Automobile(s): 09 escalade
    May 2014
    Fort Worth
    33
    1
    I pulled the 2 fuses which are under the hood and ran the tests that 99ssconv posted. The voltage drop was outside of the 200 mv (300 and 400 mv). I found out I had an extended warranty and took it to the dealer (Frank Kent Cadillac in fort worth Texas). They said it was definitely the cables and replaced all 3. They were about $100 each. but since I had a warranty I let them do it. So far so good no problems the issue seems to be resolved! thanks 99ssconv!!
  13. #27
    morlysafer Guest
    Quote Originally Posted by brianbigb03 View Post
    My wife's '07 Escalade has the same symptoms. I guess I'm a bit slow because I can't figure out how to measure this voltage drop. Can you further explain how you're measuring the drop. For the negative cable, am I putting the red lead from my multimeter on the negative battery post and the black lead on the bolt that mounts the cable to the engine block? I don't measure any voltage when doing it this way (fuel inj fuses removed and wife cranking engine). Also, from what am I measuring the drop? Is my base the 12.4v that the battery shows when placing red lead on red post and black lead on black post?
    Thank you all in advance. Our truck has been good to us, '07 original owner with 115k miles. Except for an expensive recent air-strut replacement, it's been relatively trouble free. Hopefully this is an easy fix. The negative cable looks easy enough to replace but the red one looks like it might be a bit of trouble.
  14. #28
    aces624 is offline Cadillac Owners Member
    Automobile(s): Escalade
    Dec 2015
    6
    I'm new here so I hope I'm not breaking any rules by reviving an old thread. But did anyone ever find a solution ?
  15. #29
    morlysafer Guest
    Quote Originally Posted by aces624 View Post
    I replaced the negative cable, ($100) and never had another problem. There's quite a bit of discussion about bad cables (something that rhymes with electrolysis where the cables degrade from the inside).
  16. Remove Advertisements
