Wind noise do it yourself fix!!!!! - Page 3
Page 3 of 7 FirstFirst 1234567 LastLast
Results 31 to 45 of 95
Like Tree11Likes
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Wind noise do it yourself fix!!!!! in Cadillac Escalade Forums; Thanks, I'm going to try this tonight...
  1. #31
    DancingPaul is offline Cadillac Owners Member
    73
    Re: Wind noise do it yourself fix!!!!!
  2. #32
    bstiffmanofsteel's Avatar
    bstiffmanofsteel is offline Cadillac Owners Connoisseur
    Automobile(s): NONE
    Jul 2008
    Elmhurst, IL
    38
    1,042
    He does exist... I too will look into this!
  3. #33
    balladw is offline Cadillac Owners Member
    Automobile(s): EXT
    Feb 2011
    26
    In one of the pictures this is the actual gm stripping i pulled out, it was totally separated in this area, cut it and then glued around the whole seal.
  5. #34
    48Dodge is offline Cadillac Owners Fanatic
    Automobile(s): '08 Escalade ESV
    Mar 2011
    41
    442
    I'm not sure I'm affected by the wind noise in my '08. It's not quiet like a Lexus at 75mph, but it's much quieter than my '02 Tahoe, so I don't know what to compare it to. I notice some wind noise, but probably wouldn't have realized it was a problem if I hadn't read about it on the forum. I pulled my trim off and took a look and there's already foam in that joint from the factory. Probably half an inch in on that gap. I may squirt some poly in there anyway since there may be gaps.
  6. #35
    Automobile(s): EXT
    Feb 2011
    26
    And that foam separates from the door and and air leaks in, on both my passenger and drivers doors were separated.
  7. #36
    StevieT's Avatar
    StevieT is offline Cadillac Owners Fanatic
    Automobile(s): Esclade EXT
    Jun 2010
    33
    143
    Use the [img] code:
    tiny73 and tiny73 like this.
  8. #37
    purduecmpe is offline Cadillac Owners Member
    Feb 2011
    12
    Get out the duct tape and bailing wire! More GM/Cadillac design flaws customers are left to fix.
  9. #38
    Feb 2011
    12
    Well before the pics I thought you might be a troll... Even after the pics, I had my doubts... (Could cadillac design really be this bad?) When I got home I pulled the trim as instructed... Low and behold there was some pulling away of the window seal from the metal frame!!! With the frame off I took her out for a test... At 75mph there was my annoying friend the wind noise! I placed my finger in the area where it was pulling away and... SILENCE!!! Accelerated to 85 with my finger in place and... SILENCE!!! Removed my finger and WIND NOISE! Picked up a tube of urethane, applied as directed, and now the most annoying bug in the 07 Escalade design is fixed! The urethane is messy, but it works! THANK YOU SO MUCH FOR THE PICS AND INSTRUCTIONS! If you ever find yourself in Austin, TX beer is on me!
    And if anyone from Cadillac or GM is reading this: Here is a big F U! Your dealers are selling defective designs and your service departments are refusing to fix them...
  10. #39
    Nixin's Avatar
    Nixin is offline Cadillac Owners Member
    Automobile(s): '07 Escalade ESV
    Apr 2011
    Mississauga, Ontario, CANADA
    59
    balladw, thanks for (FINALLY) posting the images and instructions. I didn't mean to bust your chop's, just having a bit of fun! I have yet to get out there and do the fix but it I am certain it will happen shortly. Cheers to you!!!
  11. #40
    sparsons79 is offline Cadillac Owners Member
    Automobile(s): 07 Escalade
    May 2010
    34
    This is awesome...going to do it this weekend!!!
    What kind of glue did you use?
    Thanks again!!!
    Quote Originally Posted by balladw View Post
  12. #41
    apathy96 is offline Cadillac Owners Member
    Jun 2010
    32
    35
    I glued mine just now, excited to see if it fixes the noise in the morning.
  13. #42
    Dobiesdaddy's Avatar
    Dobiesdaddy is offline Cadillac Owners Fanatic
    Jul 2010
    NORTVEST
    58
    101
    Most people just have the problem on the drivers side?
    There's no noise on my passengers side at all.
  14. #43
    Mar 2011
    41
    442
    Just sealed mine up with black poly from Lowes. It's still curing so I haven't had it out to test.
    Sent from my Xoom using Tapatalk
  15. #44
    Dif's Avatar
    Dif
    Dif is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 Escalade EXT
    Nov 2004
    Massachusetts
    65
    670
  16. #45
    71Dragtruck is offline Cadillac Owners Fanatic
    Automobile(s): 2008 Escalade
    Dec 2008
    Saskatchewan, Canada
    159
    Can someone who has done this take some clear pictures of where the urethane was applied?
    I pretty sure I know where, just want to be 100% clear before I start.
  17. Remove Advertisements
