Was this post helpful?
Cadillac Escalade 2007-2011 factory SuperNav/GPS/Navigation Install Instructions
1 reading
82K views 47 replies 28 participants last post by  CaMs
#1 · (Edited)
This thread will provide instructions on how to uninstall the factory Non-Nav/Radio unit from a Cadillac Escalade 2007-2011 and install the factory SuperNav/GPS/Navigation on a Cadillac Escalade 2007-2011.
I am doing this write up because about a month ago I purchased an 08 Escalade with Non-nav radio and this was the first upgrade/install I wanted to do. Instructions were hard to come by and usually vague. I hope this helps those who are looking to do the same mod. If it is helpful please vote on my poll above.
Keep in mind I have no electrical or audio/video education. Nor have I ever modded any of my previous vehicles. So, in my opinion, this install is more psychologically challenging than anything else. This install took me no more than an hour. The latches all need a significant amount of force to be released so don't be scared to pull hard. I used a plastic 4" putty knife to release panels and it was a critical tool. Make sure you have this tool or similar.
Step 1:
Remove Cup holder/Ash tray bezel. Open both the Ash tray and Cup holder. Grasp with thumbs in cup holder side and fingers in ash tray side. Firmly lift up and back (away from climate controls). There are four main latches that need to be released. Two on either side of the arm rest and two up by the climate controls on either side.
Step 2:
Use a firm flat-bladed plastic tool to pry off the trim plate above the glove box. Insert flat-bladed plastic tool underneath wood grain. Slide tool until you reach a latch. Use fingers to pull panel away and release latch. Continue to slide tool and release each latch until fully removed.
Step 3:
Use the firm flat-bladed plastic tool to pry off the trim plate from around the instrument panel. This is the panel surrounding the radio/climate controls. Start with the top right corner where you have just removed panel above glove box. Slide flat-bladed plastic tool in underneath wood grain and Once all the latches are released you will notice that there are two electrical plugs that need to be disconnected before you completely remove. Simply release the clasps with your fingers and the plugs will disconnect.
Step 4:
Remove passenger side assist handle from pillar. Use a screwdriver or similar to remove the two screw covers. Use a 10mm bit to unscrew nuts. Pull handle away from pillar.
Step 5:
Remove Pillar cover. Use fingers to pry pillar cover away. There are four main latches to release. Two up by the handle and two down by the tweeter. Disconnect tweeter by simply pressing in the latch on the connector.
Step 5:
Remove defroster panel at front-most dash. Use the flat-bladed firm plastic tool to pry up the panel. Again, insert the plastic flat-bladed tool under the panel and slide it toward the steering wheel. When the tool hits a latch use your fingers to pull up and release the latch. Continue to slide the tool along until all latches are released. [Note: I did not fully remove this panel. I did so just enough to slide in the GPS antenna. If you do fully remove you must disconnect electrical plug to compass]
Step 6:
Remove Non-nav radio. Use a 9/32 bit to unscrew nuts from around radio unit. There are six total nuts. When nuts are removed pull unit away from dash. Using fingers, unplug the audio/video cords. Also unplug the black XM/Onstar cord (I am not positive the black cord is for onstar/XM, could someone please confirm what the black cord is for).
Step 7:
Place GPS/Navigation antenna head in the slot provided under defrost panel. Run the cord from GPS/Navigation antenna to the back of the GPS/Navigation unit area. [Note: this is very simple. There are a couple of different ways to run the cord to the back of GPS unit.]
Step 8:
Plug all appropriate cords into back of GPS/Navigation unit. The cords are plugged in exactly like the Non-nav unit. Remember to plug in new GPS/Navigation antenna to appropriate port. If desired, turn vehicle on and watch GPS/Navigation unit start up. [Mine displayed the Cadillac and globe for a few seconds then read "THEFTLOCK ACTIVATED."
Step 9:
Screw GPS/Navigation unit into slot. Using the 9/32 bit screw all six nuts back into appropriate slots just as you removed them.
Step 10:
Reinstall defrost/front dash panel. Snap all appropriate latches back into place just as you removed them.
Step 11:
Reinstall passenger pillar cover just as you removed it. Plug tweeter back in at connector. Snap all appropriate latches back into place.
Step 12:
Reinstall passenger handle back into place just as you removed it. Use 10mm bit to screw nuts back into place. Replace screw covers as you removed them.
Step 13:
Reinstall the trim plate around the instrument panel (The panel surrounding the radio/climate controls). Plug electrical ports back into housing like you had removed them.
Step 14:
Reinstall trim plate above the glove box. Simply snap the trim plate back into appropriate latches.
Step 15:
Reinstall Cup holder/Ash tray bezel. Simply snap the bezel back into place like you had removed it.
AFTER picture for your reference:
#2 · (Edited)
Excellent tutorial :bouncy:
Even though I already have factory nav, your description for removing panels & the head unit will come in handy if I decide to go for a GMX-550.
Now - after all that work, I'll be interested to see what you think of the performance of the factory nav. Mine, as well as others on the forum, tends to lead us around in circles occasionally - to the point that I routinely use my iPhone with the TomTom software running just to be sure good ol' GM doesn't take me into a part of town I don't belong in. :hmm:
#3 ·
The thing attached to the defroster trim panel is the light sensor for the automatic headlights, not the compass. The compass is fully self contained within the mirror. The defroster panel removal really is the most difficult part of the whole thing because it is held in very securely. You might be able to get away with just removing the driver side assist handle and A pillar trim as it's enough to get the pulling process started. That spatula thing was the only tool I didn't have, and a as a result I ended up with a cracked defroster panel and 160.00 lighter in the wallet.
#4 ·
Also, be aware that if you get one of the aftermarket antennas like I did, that doesn't have the metal base, There are many places you can hide it or place that do necessitate removing that defroster panel. Youll just have to get it up as close to the top of the dash as possible and experiment with what works.
#6 ·
One more tip... If you do a lot of city driving like I do, and live somewhere where you know how to get around easily, take the Navigation DVD out of the DVD drive. I noticed that it tries to read that disc over and over and over and every single time you start the vehicle. On the old Escalade nav units, the DVD mechanisms would eventually wear out from all of this constant reading, even when you aren't in navigation mode. So I just take mine out and leave it in a CD case in the center console, until I actually need to use the navigation functions.
#11 ·
make sure it's 'up to date' with the latest firmware (flashed by dealer only)
also make sure you totally understand the settings/options that you have set - i've heard instances where people have really made life hard on themselves by having weird combinations of settings set that made the nav act poorly (for instance having the nav set to route by shortest distance instead of fastest time)
coming here for help is a good idea, but you do have other options for help with these nav units, so FYI here's a bit more info:
the nav disc center (where you can buy new map dvd discs) is also a navigation 'help line' fo any and all questions regarding your navigation unit (and its operation)
so if you don't understand what the nav manual is saying, or wonder about something that may not be in the manual - or if you don't even have a nav manual they can help you out
or take it to your favorite dealership and ask them for assistance​
#12 ·
Great pictures. I installed a Barracuda to allow me to change the Nav destination while driving as well as watch DVD while driving. I don't really use the DVD while driving but it comes with the package and sometime my wife likes to watch while the kids are watching a movie. I have a number of tips including how to attach the rear backup camera from black RCA to black RCA. Otherwise, the pictures posted above were great for getting the trim off of the dash, not necessary to remove the assist handle or anything else over there for the Barracuda. Let me know if you have any questions, otherwise it was a breeze.
#15 ·
Just installed the Nav radio and added a back up camera. Can't get them to talk to each other. Radio seems to be responding to programing per the instructions and the camera is a brand new GM part out of the box. (radio was purchased off of E-Bay as reconditioned. 2008 Escal. Any ideas?
#16 ·
Hello everyone. I need some help ASAP.
It appears that my dealership doesn’t how to program a 2011 Nav Unit in my 2008 Escalade. The nav unit is GM part 20955278. I have heard and seen this done to others on the internet. There is an ebay seller that advertises them and clears the VIN out to work in 2007 and 2008. They say they no longer use the Tech 2 and now the PC or something. They said if it were done by tech 2 they would be able to do it or trick it with a VIN. They said that when they start to program it they have to choose the year vehicle, etc, etc. They said they called GM and GM told them they can’t help them out and it won’t work in my 2008 Escalade. They wouldn’t give them the VCI or whatever was needed. Can someone tell me what and how to tell me how to get my dealer to be able to program the 2011 Map Drive Navigation Unit to my neighbors 2008 Escalade. My vehicle is there now and i would like to try and get them some information so they can complete it today
Thanks in advance.
#18 ·
Thanks for the response. It isnt at the dealer any longer however they never were able to get it programmed. They told me that they were going to look into it and see if they could find out what they needed to do. I have PM'd you my VIN. Thanks again and any help would be great.
#20 ·
I know it is possible because I have a 2011 Supernav and AMP from an ESV in my 2007 EXT. It uses the solid state memory card for Nav which is much quicker, sucks less power and produces less heat...it doesn't even have a cooling fan. It took two trips to the dealer to get it programmed but they were finally successful. I had a VIN for a 2011 EXT model for them to use and it was done on a computer....they had to try several profiles and overrides before it was fully functional. The amp required programming as well because of the differences between ESV/EXT speakers/wiring/rear entertainment. Happy with mine....an after effect was the ONSTAR red light I had after changing to the newer bluetooth VCIM changed to green. I checked the emergency Onstar and it works but am reluctant to mess with the regular Onstar and get that red light back. I am using a 2009 CTS VCIM.
#22 ·
I started a similiar thread, what needs to be done to get the 2011 system in? Sounds like it all plugs up, but there may be difficulties programming it? Do I need to bring it to the dealer out of the car or installed? Am I less prone to a problem if I get a supernav out an ESV to go into an ESV? Whatever issues may be, I'd like to know before I start ripping things out. If it's too much of a pain, I'll have specmo fix my radio.
-Dave
#23 ·
Gm has a bulletin out similar to the bluetooth one. They dont want the new Nav installed in older models. Why cockblock a simple mod.The radios are GM so it doesn't cut into their bottom line and the dealer makes a buck programming. I am not trading my truck for a new vcim or Nav system,maybe if they bucked up and refreshed the truck every couple years they might get better sales. You cant really tell an 07 from an11 maybe the dual exhaust on an 12 will help but not a Nav system.
#24 ·
What makes you think they want to sell more units??? :tisk:
If they sold a VCIM with Bluetooth that could go in older units that didn't have them they could a lot of money selling them and installing them.
But why would they want to to make money?:stirpot:
#25 ·
IMHO, Potential profit does not overcome potential liability from "Onstar Accident/vehicle status Reporting" feature not operating as designed because of mismatched software/hardware.....Some one would probably sue them if the mismatched equipment/software did not report an accident or a vehicle condition that resulted in serious injury or damage to the vehicle. I personally would be glad to sign a waiver acknowledging that those conditions could happen and I would find GM not responsible, but the problem resurfaces when (if) I sell the vehicle and the new owner or several down the line is unaware of the modifications. Just look at the final "FIX" for the heated windshield fluid which is a much less complex technical issue.
#27 ·
PLEASE HELP :suspense:))
Hi I have a 2007 escalade and i have the non-nav radio. I purchase a navigation radio off eBay I had it
install and it said theftlock activation. I took it to the dealer and they are trying to charge me 3000 to
change out my harness.... They told me thats the only way it will work is to have a GMC navigation
harness..will this work for me also if I purchase a gps/nav antenna?
