Cadillac Escalade 2007-2011 factory SuperNav/GPS/Navigation Install Instructions - Page 2
View Poll Results: Was this post helpful?
Voters
26. You may not vote on this poll
  • Yes! Thank you.
    25 96.15%
  • No! I hope your GPS causes you to hit a light pole and knock out your two front teeth.
    1 3.85%
Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 48
Like Tree3Likes
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Cadillac Escalade 2007-2011 factory SuperNav/GPS/Navigation Install Instructions in Cadillac Escalade Forums; ...
  1. #16
    biglg is offline Cadillac Owners Member
    Automobile(s): Cadillac Escalade
    Aug 2008
    31
    Re: Cadillac Escalade 2007-2011 factory SuperNav/GPS/Navigation Install Instructions
    Hello everyone. I need some help ASAP.
    It appears that my dealership doesn’t how to program a 2011 Nav Unit in my 2008 Escalade. The nav unit is GM part 20955278. I have heard and seen this done to others on the internet. There is an ebay seller that advertises them and clears the VIN out to work in 2007 and 2008. They say they no longer use the Tech 2 and now the PC or something. They said if it were done by tech 2 they would be able to do it or trick it with a VIN. They said that when they start to program it they have to choose the year vehicle, etc, etc. They said they called GM and GM told them they can’t help them out and it won’t work in my 2008 Escalade. They wouldn’t give them the VCI or whatever was needed. Can someone tell me what and how to tell me how to get my dealer to be able to program the 2011 Map Drive Navigation Unit to my neighbors 2008 Escalade. My vehicle is there now and i would like to try and get them some information so they can complete it today
    Thanks in advance.
  2. #17
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,722
    Is the vehicle still at the dealership? Has the dealer found out any new information? If you want to send me your Vin number I can see if I can find out any more information for you.
    Breanne
  3. #18
    Aug 2008
    31
    Thanks for the response. It isnt at the dealer any longer however they never were able to get it programmed. They told me that they were going to look into it and see if they could find out what they needed to do. I have PM'd you my VIN. Thanks again and any help would be great.
  5. #19
    prosseda is offline Cadillac Owners Member
    Automobile(s): 2007 Escalade EXT 2009 Platinum ESV
    Aug 2006
    91
    I googled one of the sellers on Ebay and called them. I think the guy I talked to was Tom. He said he can program the unit for $100. You would have to ship it to the company.
  6. #20
    WaterKing is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Escalade EXT and 2012 Volt
    Jan 2009
    Northwest Alabama
    69
    365
    I know it is possible because I have a 2011 Supernav and AMP from an ESV in my 2007 EXT. It uses the solid state memory card for Nav which is much quicker, sucks less power and produces less heat...it doesn't even have a cooling fan. It took two trips to the dealer to get it programmed but they were finally successful. I had a VIN for a 2011 EXT model for them to use and it was done on a computer....they had to try several profiles and overrides before it was fully functional. The amp required programming as well because of the differences between ESV/EXT speakers/wiring/rear entertainment. Happy with mine....an after effect was the ONSTAR red light I had after changing to the newer bluetooth VCIM changed to green. I checked the emergency Onstar and it works but am reluctant to mess with the regular Onstar and get that red light back. I am using a 2009 CTS VCIM.
  7. #21
    hdmech is offline Cadillac Owners Member
    Automobile(s): 2007 escalade , 87 GN
    Apr 2010
    Toronto
    55
    38
    This is probably not going to help those who are trying to do a nav swap. Hopefully we can find helpful dealerships. http://www.sandyblogs.com/techlink/2...striction.html
  8. #22
    Aerohokie is offline Cadillac Owners Member
    Automobile(s): 2008 Escalade ESV
    Dec 2011
    19
    I started a similiar thread, what needs to be done to get the 2011 system in? Sounds like it all plugs up, but there may be difficulties programming it? Do I need to bring it to the dealer out of the car or installed? Am I less prone to a problem if I get a supernav out an ESV to go into an ESV? Whatever issues may be, I'd like to know before I start ripping things out. If it's too much of a pain, I'll have specmo fix my radio.
    -Dave
  9. #23
    Big Windy Ext's Avatar
    Big Windy Ext is offline Cadillac Owners Enthusiast
    Automobile(s): Caddy EXT
    Aug 2009
    Downers Grove Il
    633
    Gm has a bulletin out similar to the bluetooth one. They dont want the new Nav installed in older models. Why cockblock a simple mod.The radios are GM so it doesn't cut into their bottom line and the dealer makes a buck programming. I am not trading my truck for a new vcim or Nav system,maybe if they bucked up and refreshed the truck every couple years they might get better sales. You cant really tell an 07 from an11 maybe the dual exhaust on an 12 will help but not a Nav system.
  10. #24
    krieghoff is offline Cadillac Owners Fanatic
    Automobile(s): ESV
    Dec 2009
    361
    What makes you think they want to sell more units???
    If they sold a VCIM with Bluetooth that could go in older units that didn't have them they could a lot of money selling them and installing them.
    But why would they want to to make money?
  11. #25
    Jan 2009
    Northwest Alabama
    69
    365
    IMHO, Potential profit does not overcome potential liability from "Onstar Accident/vehicle status Reporting" feature not operating as designed because of mismatched software/hardware.....Some one would probably sue them if the mismatched equipment/software did not report an accident or a vehicle condition that resulted in serious injury or damage to the vehicle. I personally would be glad to sign a waiver acknowledging that those conditions could happen and I would find GM not responsible, but the problem resurfaces when (if) I sell the vehicle and the new owner or several down the line is unaware of the modifications. Just look at the final "FIX" for the heated windshield fluid which is a much less complex technical issue.
  12. #26
    CaMs is offline Cadillac Owners Member
    Jun 2007
    70
    Quote Originally Posted by prosseda View Post
    Can you send me this company info?
  13. #27
    Lady is offline Cadillac Owners Member
    Feb 2013
    PLEASE HELP ))
    Hi I have a 2007 escalade and i have the non-nav radio. I purchase a navigation radio off eBay I had it
    install and it said theftlock activation. I took it to the dealer and they are trying to charge me 3000 to
    change out my harness.... They told me thats the only way it will work is to have a GMC navigation
    harness..will this work for me also if I purchase a gps/nav antenna?
  14. #28
    cadmanchris's Avatar
    cadmanchris is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 DTS,2007 STS V8
    Dec 2006
    New Jersey
    45
    601
    Never heard of changing out the harness. I've done a couple at work and had no issues. You will need the GPS antenna for the nav to work. The backup camera is another story.
  15. #29
    Feb 2013
    So once I buy the antenna it will work
    Quote Originally Posted by cadmanchris View Post
    So once I buy the antenna it will work?
    Do I have to have it program?
  16. #30
    Dec 2006
    New Jersey
    45
    601
    Yes the radio would have to be programmed to remove the theft lock. Once you have the GPS antenna, the nav will work.
  17. Remove Advertisements
