Free 2011 Nav Disk - Page 5
Page 5 of 19 FirstFirst 123456789101112131415 ... LastLast
Results 61 to 75 of 281
Like Tree7Likes
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Free 2011 Nav Disk in Cadillac Escalade Forums; Yes I ment for myself.... I never take the disk out but it is hammered???? I guess the other ownerr ...
  1. #61
    smorgan's Avatar
    smorgan is offline Cadillac Owners Member
    Automobile(s): 05 CTS-V 07 Escalade
    Apr 2008
    Telford PA
    30
    Re: Free 2011 Nav Disk
    Yes I ment for myself.... I never take the disk out but it is hammered???? I guess the other ownerr must have taken it out once in a while. Im thinking I might try to make a back up copy and see if it reads. What I want to know is if the nave unit took a dump.
  2. #62
    paperchase4life is offline Cadillac Owners Member
    Automobile(s): escalade ext 07
    Mar 2010
    67
    Emailed them last Tuesday, arrived today in the mail. Now I have 2010 and 2011 copy...
  3. #63
    worpdrive is offline Cadillac Owners Member
    Automobile(s): 07 Escalde
    Jan 2011
    MA
    5
    Thanks for this post!
    I called the number and followed the prompts for the Navigation update. When I got to an operator, I told them I got a post card for a Nav update. When they asked for the post card number, I replied I didn’t have it in front of me but did have the Vin number. I gave them the Vin number and they said I we eligible, so they took down my address and mailed me a 2011 Nav update dvd. WooooWhooo!
  5. #64
    Canuck714 is offline Cadillac Owners Member
    Automobile(s): 07 Escalade
    Jan 2011
    Texas
    10
    OK, as others have done, I too called NavDisk and got the free "goodwill" disk sent. When it got here I ejected the 2007 Nav Disk (version 1.0) and installed the new Nav disk (version 9.3) Loads and sends error message that the disk is not a map disk!!!! Clearly written on the front of new disk is MAP DISK... What gives?? Anyone else have this issue?
  6. #65
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,969
    canuck, call up the navdisc center and see what they have to say about it... the disc could be bad (or maybe you need a software update)
  7. #66
    Dave DiGabriele's Avatar
    Dave DiGabriele is offline Cadillac Owners Member
    Automobile(s): 2007 EXT
    Jan 2011
    Webster, New York, United Stat
    18
    I received mine today thanks for the heads up.
  8. #67
    Jan 2011
    Texas
    10
    Rip,
    Nav Disk said take it to the dealer and see if the disk is in fact bad. If its not the disk, how do I get the software update?
  9. #68
    Sep 2007
    Wilmington, NC
    13,969
    if the disc isn't bad the nav unit could be bad... the dealer will try to update the software (if there is an update) as part of the steps to diagnose if the nav unit is bad
    i assume they'll just swap the disc at first to see if the disc from another truck (that they know works) will work in yours... if it does then that's a good indication that the disc is bad... if it doesn't then it's likely that the unit is bad (either needing an update or replacement)
    now that i'm thinking about this a bit more i'm leaning towards a software problem being the least likely culprit (and therefore a update won't really help) - it's more likely a hardware problem with the disc drive or some other electrical part failing
  10. #69
    Jan 2011
    Texas
    10
    Funny thing is, the Caddy disk that it came with in 07 works fine. I put it back in so we could still have Nav, so I cant see it as a unit problem. Lets hope for software update.
  11. #70
    Sep 2007
    Wilmington, NC
    13,969
    Yeah that sounds like a bad disc (but i guess it could be software too) ... did you tell the navdisc center people that you were able to get your old disc to work?
  12. #71
    Jan 2011
    Texas
    10
    yep. Thats why they think it software... we will see.
  13. #72
    RichieRich's Avatar
    RichieRich is offline Cadillac Owners Fanatic
    Automobile(s): 2013 Escalade
    Sep 2006
    Philly
    287
    I tried this... No dice! LOL... They told me it ended in 2009 & that was that... I'll call back...
  14. #73
    smorgan's Avatar
    Apr 2008
    Telford PA
    30
    I had to call back but I still have a read error with the new disk so it's got to go in Monday
  15. #74
    RichieRich's Avatar
    Sep 2006
    Philly
    287
    It worked! You guys were right... I called back a second time and they said ok, no problem and sent it right out! Thanks for sharing this great info!
  16. #75
    magnumforc is offline Cadillac Owners Member
    Automobile(s): 2010 Cadillac CTS Sport Wagon
    Dec 2010
    California
    9
    Does anyon know whether the disk is VIN dependent or whether the ID authorization code will allow the disk to work on multiple vehicles? I note the VIN is printed on the paperwork that comes with the disks along with the authorization code, so wonder if the same disk is good in a number of vehicles? The salesman at my dealership says they will simply order one disk and then use it in all the cars needing an upgrade. If so, what prevents a group ordering just one disk?
  17. Remove Advertisements
