New Platinum Escalade Owner....problem with RSE factory headrest DVDs????
Results 1 to 9 of 9
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, New Platinum Escalade Owner....problem with RSE factory headrest DVDs???? in Cadillac Escalade Forums; Should the dvd in the head unit be able to be viewed on all 3 rear screens at the same ...
    jcrack_corn is offline Cadillac Owners Member
    Automobile(s): NONE
    Sep 2010
    37
    18
    Should the dvd in the head unit be able to be viewed on all 3 rear screens at the same time?
    Right now it only shows on the flip down center screen. and in the options there are no options for monitor 2 or monitor 3, just the flip down screen (i can route head unit to it, or Aux to it).
    On the rear headrests, the are seeing each other correctly as monitor 3 or 4. i can play a dvd in one and see it in the other with no problem.
    Sources available are
    Monitor 3 (or 4) (from the OTHER headrest)
    Aux
    channels (yes, i thought this was not supposed to be available, maybe thats my problem) -- these channels are 2-69 and none of them show anything
    and DVD (from the unit itself)
    Is there a brain unit for these two screens I should check, or any programming that can be done? What are the channels for?
    -this car is used and did have GM322 and Ipod installed but I removed all of it to troubleshoot....everything including XM works as its supposed to except for seeing the head unit dvd on the headrest screens.
    THANKS!
    Automobile(s): NONE
    Sep 2010
    37
    18
    Re: New Platinum Escalade Owner....problem with RSE factory headrest DVDs????
    ok, i've now figured out that the manual is referring to ESV's with a third row screen, and that you CANT get video from nav unit to the head rest screens.
    however, this should be VERY easy to accomplish by using the av1600 cable and interfacing right at the brain/switch box for the two screens (each screen has input and output to that box, I can take the output of screen 3, splice in the the output of the nav dvd unit then:
    screen 3 will play only from its dvd or front panel aux port
    screen 4 will play from its dvd, front panel aux or nav dvd unit (when "monitor 3") is selected.
    so does anyone know where the brains are? i am assuming behind the radio or climate control or in the center console, but its much easier if someone already knows the location (the wires seem to go forward, so i'm thinking behind radio/climate).
    2009 platinum, thx!
    Platinum ESV is offline Cadillac Owners Member
    Automobile(s): 2008 Escalade EXT, 2009 Escalade ESV Platinum, 2008 SRX4 V8
    Nov 2007
    North Carolina
    14
    Pull the left side console panel off and you'll find the control box for the headrests right there sticky taped to the subwoofer enclosure. I swapped mine out for the upgraded one with a aux input.
  5. #4
    Automobile(s): NONE
    Sep 2010
    37
    18
    thanks!
    Do you mean the side panel on the drivers side of the center console? or somewhere else..?
    and what is the item/part number for the upgraded brains with aux input?
    thanks a ton!
  6. #5
    Automobile(s): NONE
    Sep 2010
    37
    18
    spent a couple hours today rewiring it...all works perfect now.
    i tapped the video out of the control box for each screen and added rca plug.
    I also tapped the video out of the nav unit and added a rca plug.
    Now it is all fully customizable, and all screens (nav, overhead, 2x headrests) play the front DVD at the same time.
    the headrests CANNOT show with the other headrest is playing anymore (dumb "feature anyway). of course if they both need to be on the same thing, I can just play the dvd up front!
    pics comming
  7. #6
    Nice Ride is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 ESV Platinum / 2013 SRX Premium
    Jan 2012
    1,240
    Anyone have photos or schematics? I have an 09 esv. This is how things should be from the factory.
  8. #7
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,274
    Quote Originally Posted by jcrack_corn View Post
    pics comming
    If you have kids you would understand why it comes from the factory like it does, because they will not watch the same things, or listen to the same things, so it would cause more problems if it was not set up the factory way.
  9. #8
    sasakura is offline Cadillac Owners Member
    Automobile(s): Cadillac
    May 2008
    16
    Quote Originally Posted by Nice Ride
    X2 plus any part numbers.
  10. #9
    JBuckleyUD is offline Cadillac Owners Member
    Automobile(s): Escalade ESV
    May 2004
    10
    jCrack, Can you elaborate on how you did this? Where is the control box for the dvd screens? What wires did you tap off of each component? Thanks.
  11. Remove Advertisements
