12v Ignition-switched power source
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 20
Like Tree2Likes
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, 12v Ignition-switched power source in Cadillac Escalade Forums; I am right in the middle of hard wiring my radar detector in my 09 escalade and I need some ...
    JHC828's Avatar
    JHC828 is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac Escalade ESV Platinum / Infiniti M56S / Lexus LS430
    Feb 2009
    AR
    31
    145
    I am right in the middle of hard wiring my radar detector in my 09 escalade and I need some help with an ignition switched power source. I've tested all of the fuses in the fuse box but have came up short of finding one that actually goes off. I've searched and found some talk of another black fuse box next to the brake pedal but there are no pictures of what exactly they tapped into in that box. Anyone who has done this, I'd GREATLY appreciate some help!!!
    CadX6 is offline Cadillac Owners Fanatic
    May 2004
    247
    Re: 12v Ignition-switched power source
    Behind the black plastic snap off cover on the inside firewall (just to the left of the brake pedal) are three small "spade" contacts, at least one of which is switched 12 volt (I think the other is constant 12v & not sure what the 3rd is - maybe ground). I use that for the switched power for my iPhone cradle.
    If you can't find them, let me know & I'll grab a digital pic & post it.
    JHC828's Avatar
    Feb 2009
    AR
    31
    145
    Quote Originally Posted by CadX6 View Post
    Thanks for the reply! I think I found the box that you're talking about but I don't know exactly what "contacts" you're talking about. Maybe I'm looking at an alternative black box. There are 6 connectors inside that box and that's all I see. Maybe the 09 is different than previous models? A pic would be awesome!
    steve841's Avatar
    steve841 is offline Cadillac Owners Fanatic
    Automobile(s): Escalade ext
    Jun 2009
    Ft. Lauderdale, FL
    47
    134
    Here ... best thing you'll ever invest in.
    http://stealthcords.com/shop/home.php?cat=280
    And .. no cuts, no splices, nothing hanging, nothing fished behind the pillar or headliner.
    JHC828's Avatar
    Feb 2009
    AR
    31
    145
    Quote Originally Posted by steve841 View Post
    You still have to have a power source.
    AND I don't have a valentine, either.
    May 2004
    247
    Quote Originally Posted by JHC828 View Post
    Sorry 'bout that. When I wrote that last night there was a nasty thunderstorm going over & I was too lazy to trek down & out to the garage to verify what I was saying. So much for my memory (& I've only had this Escalade for 4 months )
    See if these help - Mine is also an 09, but my defective memory seems to recall that my 07 was the same.
    You can see where my black wire (didn't have any red handy) goes into the block. That group of connectors is what you want to work with. Easy to find which is which with a test light. I just used a small female spade connector with a piece of heat shrink around it to keep it from touching any of the other connectors - it's kind of tight in there.
    If your parts dept. could come up with a part number for the connector that fits that section of the block - you could probably make up a really slick, clean plug in for your accessories.
    steve841's Avatar
    Jun 2009
    Ft. Lauderdale, FL
    47
    134
    The power source is the mirror wiring harness/connector. You have switched power 6 inches from the radar.
    And .. they make it for several brands....
    JHC828's Avatar
    Feb 2009
    AR
    31
    145
    Well, I called myself looking for one, I only found them for the valentine and a few select (higher end) others. I couldn't find one for my cheap-O Cobra. I hope I didn't overlook it! Regardless, I've cut the wire and ran it to the fusebox area. I'm just having trouble finding a switched power source.
    Here is what my fuse box looks like:
    I have an extra connector in that location with one single wire in it. Idk if my box is wired differently or what the deal is. I don't have a test light either, I may have to invest in one.
    May 2004
    247
    Looks like you do already have a plug in that spot that I don't. Makes it really easy. Check an auto parts place or your dealer for the correct crimp on connector & just insert it in the correct hole in the connector shell (it just snaps in).
    You must have an option that I don't - RSE or power running boards?
    If I'm not mistaken, I'm connected to pin #8 (bottom row - far left)- your connector looks like it's numbered so it should be easy.
    Needle point test lights are cheap at Auto Zone (or any other parts house). Also good for probing individual wires if you're planning on making a connection for something in mid wire with an in-line, crimp on tap.
    AFKlingon and AFKlingon like this.
    JHC828's Avatar
    Feb 2009
    AR
    31
    145
    Thanks for all the help... I will stop by anautopartsstoreofsomesort tomorrow when I leave the office and grab a test light. I don't have the auto running boards (I desperately wish I did!!!) Idk what that stray wire may be, it sure was throwing me off! I will try the same pin and see if it's the one I need and I will update here for future reference.
    May 2004
    247
    Good Luck
    steve841's Avatar
    Jun 2009
    Ft. Lauderdale, FL
    47
    134
    You do realize you can buy one of the stealthcords connectors and cut off the end, splice your radar's oem connector into it and run it from the mirror ... right?
    You'd be far less frustrated and much less fishing involved.
    JHC828's Avatar
    Feb 2009
    AR
    31
    145
    Update: The same pin (far left, bottom row) is an ignition shiwched power source. Thank you for all your help!
  16. #14
    GrandmasTeeth is offline Cadillac Owners Member
    Automobile(s): 2007 Escalade
    Aug 2011
    I tapped into this and the escalade started throw codes.
  17. #15
    murphy's Avatar
    murphy is offline Cadillac Owners Enthusiast
    Automobile(s): 2009 Cadillac Escalade Platinum
    Dec 2008
    Alberta,Canada
    813
    I use http://www.invisicord.com/index.html for my escort in my Escalade and V1 in my Z06..very slick and easy to connect to mirror plug..
  18. Remove Advertisements
