12v Ignition-switched power source - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
Like Tree2Likes
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, 12v Ignition-switched power source in Cadillac Escalade Forums; How is that box cover suppose to come off? I just pryed it off, what is the correct way to ...
  1. #16
    escalade kidd is offline Cadillac Owners Fanatic
    Automobile(s): 2009 Escalade EXT
    Apr 2010
    NJ
    55
    139
    Re: 12v Ignition-switched power source
    How is that box cover suppose to come off? I just pryed it off, what is the correct way to remove it?
  2. #17
    teebo is offline Cadillac Owners Member
    Automobile(s): 1999 Escalade, 2008 Escalade
    Jul 2009
    Louisville, KY
    32
    CAdX6,
    Here is the part number for the connector. ACDelco #13504592, and Alt number is PT2489. Check Rockauto.com, they sell it for $31.79. The connector is for rear seat ent., or municipal service vehicle with a code (5W4). This is how it is listed on the website.
    ACDELCO Part # PT2489 More Info {#13504592}
    CONNECTOR,BLK-INSTRUMENT PANEL WRG JUNC w/MUNICIPAL SERVICE VEHICLE(5W4) or RR SEAT HEAD RST W/DVD(AYE); Base Model; ESV Platinum; Platinum; ESV Model
    * Non-stock item--shipping delayed up to 5 business days
  3. #18
    CadX6 is offline Cadillac Owners Fanatic
    May 2004
    247
    Useful info - Thanks.....
  5. #19
    85glh is offline Cadillac Owners Member
    Automobile(s): 08 escalade luzury
    May 2013
    1
    Red faceRe: 12v Ignition-switched power source
    Quote Originally Posted by CadX6 View Post
    Sorry 'bout that. When I wrote that last night there was a nasty thunderstorm going over & I was too lazy to trek down & out to the garage to verify what I was saying. So much for my memory (& I've only had this Escalade for 4 months )
    See if these help - Mine is also an 09, but my defective memory seems to recall that my 07 was the same.
    You can see where my black wire (didn't have any red handy) goes into the block. That group of connectors is what you want to work with. Easy to find which is which with a test light. I just used a small female spade connector with a piece of heat shrink around it to keep it from touching any of the other connectors - it's kind of tight in there.
    If your parts dept. could come up with a part number for the connector that fits that section of the block - you could probably make up a really slick, clean plug in for your accessories.
    This was very helpful..........thank you!!
  6. #20
    po8pimp is offline Cadillac Owners Member
    Automobile(s): 2007 Escalade
    May 2011
    1
    OMG you are a life saver. I have been looking for two days for a 12v switched power source. I have an 07 with the exact same box and sure enough switched power at the same point. I have gone through schematic after schematic with no luck. GM doesn't have very friendly Service manuals. I have installed 4 headrests and wired everything but power then all stop scratching my head wondering WTF. Thank you so very much.
  7. Remove Advertisements
