OBDII Communication Failure
Results 1 to 9 of 9
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, OBDII Communication Failure in Cadillac Escalade Forums; Just took the truck to get the NYS inspection and it failed because the the car could not communicate with ...
    GreenLade's Avatar
    GreenLade is offline Cadillac Owners Member
    Aug 2005
    34
    Just took the truck to get the NYS inspection and it failed because the the car could not communicate with the state computer to run the emissions, anybody else ever had this. The tech said it could just be a fuse. Anyone know about this? It said the connectors are OK, but not communicating.
    dixit's Avatar
    dixit is offline Cadillac Owners Member
    Automobile(s): 14 CTS-Vsport
    Jul 2009
    ATL area
    40
    89
    Re: OBDII Communication Failure
    Its your 20Amp fuse under the hood. Its labelled I believe as LTR (for Cigarette Lighter) I believe. Im not in front of my car to know for sure. But i want to say the fuse is in the 50 range, its labelled as 50 or something. Take a look. That cigarette lighter fuse actually also controls the OBDII plug power, so if thats blown you cannot get the OBDII/CAN to talk to the computer because 12V is missing.
    This will fix your problem for sure, just replace that burned out 20A fuse.
    Dixit
    LeftLane is offline Cadillac Owners Fanatic
    Automobile(s): ESCALADE
    Dec 2009
    161
    All state inspections blows I'm so glad Ohio trashed ours
    steve841's Avatar
    steve841 is offline Cadillac Owners Fanatic
    Automobile(s): Escalade ext
    Jun 2009
    Ft. Lauderdale, FL
    48
    134
    Quote Originally Posted by LeftLane View Post
    DITTO for Florida!
    What a joke that whole scam is !!!
    GreenLade's Avatar
    Aug 2005
    34
    Quote Originally Posted by dixit View Post
    Dixit
    I forgot to put the year of the truck, it is an 07, do you think the same applies? Are 2nd gen Escalades the same with this as 3rd gen? Just wondering because my cousin has an 02 .
    GreenLade's Avatar
    Aug 2005
    34
    Dixit
    You were right the fuse was blown, i will take it back to get re-inspected tomorrow and know for sure. Thanks for the info.
    dixit's Avatar
    Jul 2009
    ATL area
    40
    89
    Good deal.
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    The machine looks for power on pin 16 on the DLC (connector), if the fuse is blown it will fail for no communication.
    On Escalade for some unknown (and stupid) reason they power the DLC with the same fuse that works the cigar lighter.
    The cigar lighter in in an awful position on Escalade and it apparently has a coin magnet inside of it.
    Coin + open cigar lighter socket = blown fuse.
    I have lost count of how many times I have seen this happen.
    GreenLade's Avatar
    Aug 2005
    34
    Good to know, thanks.
  12. Remove Advertisements
