battery died now nav radio will not turn on!! - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 37 of 37
Like Tree1Likes
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, battery died now nav radio will not turn on!! in Cadillac Escalade Forums; What nav do you ? I would try to disconnecting your battery and back....
  1. #31
    SpyShops NY's Avatar
    SpyShops NY is offline Cadillac Owners Enthusiast
    Automobile(s): 1999 Escalade, 2004 CTS, 2003 ESV, Now 2008 Escalade
    Oct 2012
    Fresh Meadows, NY
    38
    847
  2. #32
    kyescalade is offline Cadillac Owners Member
    Jul 2014
    1
    Quote Originally Posted by SpyShops NY
    The computer won't always reboot automatically.mysystem went out at the Dealer too. Just pull fuse for nav system under the hood and reinsert. It has fixed mine several times
  3. #33
    asudevilboy80's Avatar
    asudevilboy80 is offline Cadillac Owners Member
    Automobile(s): 2007 Cadillac Escalade
    Nov 2009
    Scottsdale, AZ
    18
    Re: battery died now nav radio will not turn on!!
    Same issue..battery died, jumped it and now the factory nav won't turn on.
    I read the suggestions in this forum and first disconnected the positive connector on the battery for 60 seconds...that did not work. Do I need to disconnect the negative instead? Or both?
    Then I tried pulling the fuse (RDO #41) and that did not work either.
    I have a lockpick installed, so wondering if that is the issue. I did not install it myself and am not skilled enough to disconnect it.
    I would REALLY like to avoid going to the dealer, so any other suggestions are welcome.
  5. #34
    Punmax is offline Cadillac Owners Enthusiast
    May 2009
    27
    993
    Quote Originally Posted by asudevilboy80 View Post
    http://www.youtube.com/watch?v=diCScDqZhmw
    It's easy removing the nav. You can try disconnecting the lock-pick and see if that resolves your problem.
  6. #35
    Wilsonson1 is offline Cadillac Owners Member
    Automobile(s): 2007 Cadillac Escalade EXT
    Aug 2015
    1
    Unplugged the battery a second time and it works! Thanks for this thread!
  7. #36
    tonysailor is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jun 2007
    29
    I have 08 STS I have had this problem before. I bought a new battery (dealership) and new ( not a refurb) nav unit.
    Less than 10 months the battery needed replacement (dealership) again, no charge. Yes, the NAV unit is out again, ( 9 months old)It is now dealership they are trying to figure out what is wrong. I am not buying a nav unit again! It worked before going in and and did not work coming out.
    Let you all know!
    Tony
  8. #37
    johnnyk36 is offline Cadillac Owners Member
    Nov 2013
    My 2011 escalade did the same thing. I tried resetting the battery, checked all the fuses, noting help until I pressed and held down the radio knob and turned at the same time with the key on and that turned the radio/navigation screen on its now working fine.
    Hope this helps someone else good luck.
    rapposm likes this.
  9. Remove Advertisements
