Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac Escalade Forums > Cadillac Escalade, EXT and ESV Forum - 2007+
Cadillac Escalade, EXT and ESV Forum - 2007+ Forum for discussions regarding the Third Generation Escalade 2WD, AWD, EXT and ESV.
cadillac-escalade
Cadillac Forums: Diablosport Predator settings
  #16 (permalink)
Old 07-09-09, 10:27 AM
TSS's Avatar
TSS TSS is online now
Cadillac(s): 2007 Escalade; 2001 SLS
View TSS's Photo Album
Casino Cash: $11141
Re: Diablosport Predator settings
Keep us posted - all I have is the K&N filter and the Preditor. Very pleased.
  #17 (permalink)
Old 07-13-09, 12:32 AM
Dif Dif is offline
Cadillac Owners Enthusiast
Cadillac(s): 2007 Escalade EXT
View Dif's Photo Album
Casino Cash: $12396
I haven't been watching the Forum much:
Bought a C6 Vette and have been busy with that for last 3 months
With all the posts, and most of them positive:
I'm surprised the Predator is still be discussed like it's undecided whether it makes an improvement or not.
I only have the K&N air filter for mods and run the 93 Predator Performance tune in my EXT.
It Makes A Difference in a Very Good way
Any info about not being able to program the Trans is true but,.. the Trans shifts better and.. Less Often with the Tune installed.
The reason being is the Trans senses when the engine is starting to Lug/Struggle when more gas is given, so in turn, it down shifts to let the engine make more power with more RPM.
With the Tune installed, the Motor makes more power easier and the Trans does not sense the engine Lugging as much so, it does not down shift as much.
I took my Tune out of the EXT a while back to update it for the Vette.
I didn't put it back in and drove to the moutains, 200 mile drive.
I had forgotten how much the EXT down shifted without the Tune.
Also for that reason I noticed less MPG.
With that in mind, as far as Modifying the Tune to make it even Better....
I learned a lot on the Vette Forum under the C6 Scan & Tune section.
It's invloved and time consuming so not going to post all the info.
But, doing so makes a BIG improvment over the stock Performance Tune which is still a Nice improvement.
Each vehicle has to be done to itself, can't just take reading from someone elses Tune and put them in.
It involves running the vehicle, making a Log, saving the log, printing it out, reading it to make adjustments to what you want it to do to make it better.
Then, .. do it all again to test the results and most likely make more changes
Anyway, to anyone getting the Predator Tuner and installing it:
Be aware, there is a "Slight" instant noticable difference but,...
it takes a few miles, about 100 or so for the Tune to really take hold.
The ECM has to learn the new Program and Peformance and enjoyment will progressively get Better.
Check out some of the info as I mentioned on the Vette Forum, Scan & Tune section.
  #18 (permalink)
Old 07-13-09, 06:39 PM
Cadillac(s): Escalade ext
View steve841's Photo Album
Casino Cash: $3510
Leery was my problem ... $350 for ????? So, mine was put in today .. . and it is peppier ... Haven't hit WOT yet ... but we shall see. Impressed? No. Disappointed? No. Still on the fence? Yes.
  #19 (permalink)
Old 07-15-09, 01:03 AM
Cadillac(s): 2008 Escalade
View txlaw2002's Photo Album
Casino Cash: $460
I just got a predator and I installed it on Monday. I immediately floored it and it topped out at 115mph on speedo (my gps said 110). Prior to the predator, the ESC would stop at approx 107mph. Do I need to modify my settings to remove the top speed??? My 2004 avalanche 5.3L with hypertech would hit 130 mph, so I figure ESC should go faster. I want to install my k&N Cold air kit. Do I need to modify any settings for the k&n??? Thanks.
  #20 (permalink)
Old 07-15-09, 09:02 AM
TSS's Avatar
Casino Cash: $11141
That is just too fast, 130 in an Avalanche or Lade. But, yes, to increase speed limiter, you go to adjust parameters/modify tune. There is an option to raise or eliminate speed limiter. Please be careful.
diablosport, predator, settings
Censor is OFF
