Cadillac Escalade, EXT and ESV Forum - 2007+ Forum for discussions regarding the Third Generation Escalade 2WD, AWD, EXT and ESV.
 | Cadillac Forums: wiper icing issue?
01-28-09, 10:55 AM
| | Cadillac Owners Member Cadillac(s): Cadillac CTS-V,XLR, Escalade, STS | | Join Date: Oct 2008 Location: Trumbull, CT | | | wiper icing issue? I have a 2007 Escalade that has a continuing issue when we get snow or freezing rain that ice builds up on the wipers causing them not to clear the windshield properly. Dealer replaced the blades (after i repeatedly said that wouldn't work). My wifes STS has the same blades (the one piece flexible) and has the same problem but to a lesser degree.
Design flaw?
should i just switch the blades out for conventional "hinged" type? |
01-28-09, 12:13 PM
|  | Keeping an eye on things Cadillac(s): none | | Join Date: Jun 2004 Location: Arkansas Age: 33 | | | Re: wiper icing issue? I hope you discover an answer to this problem. Every vehicle I've ever owned has ice cake on the wipers when there's icy precipitation. I have often thought of trying to create some kind of low current warmer to charge the wiper arms and keep ice from accumulating, but it doesn't seem like an easy task. I have found there's no amount of windshield de-icer will keep that ice from growing either.
__________________ The above post is my 2 cents....nothing more.
ฏฏ;====ฑ-
!ฏนถ |
01-28-09, 12:25 PM
| | Cadillac Owners Member Cadillac(s): Cadillac CTS-V,XLR, Escalade, STS | | Join Date: Oct 2008 Location: Trumbull, CT | | | Re: wiper icing issue? thanks, just seems that on this version of escalade it is worse. My father has same truck and changed to "conventional" hinged wipers and it got to the point of what you would expect.
I get ice within first couple miles. (i can extend time by running defroster full out with temp set at 85, that get's me a few more miles)
neighbors tahoe with old style wipers have no issue.... |
01-28-09, 12:38 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2007 Escalade; 2001 SLS | | | | | Re: wiper icing issue? Same issue. But, I seem to recall having it on my 01 Tahoe too. SRX, strangely, did not have it. SLS has it to a much lesser degree.
With the Lade, I use the heated windshield fluid to correct/melt ...works most of the time. I also "bang" the wipers in addition to clearing off snow/ice before driving. |
01-30-09, 08:58 AM
|  | Cadillac Owners Fanatic Cadillac(s): Cadillac | | Join Date: Aug 2008 Location: Arkansas | | | Re: wiper icing issue? I'll second the banging the blade on the windshield. Every vehicle that I have ever owned has had these issues. All 30 or 40 of them. I seemed to have lost count now. |
02-04-09, 02:01 PM
| | Moderator Cadillac(s): 2009,2008,2007 Escalade's, 2008,2006 SRX's | | Join Date: Apr 2003 Location: Huntingdon Valley, Pa. | | | Re: wiper icing issue? I live in snowland USA, I have had 6 Suburban's, 3 Esclade's and 26 Grand Cherokee's, I have used every wiper blade made at some point, and if you get enough snow or ice you will get ice build up, it a matter of getting the ice/snow away from your windshield, the newer cars/trucks are more areo in their windshield design and the snow and ice seems to want to stay there longer.
__________________ Carl V.
**Authorized Zaino Distributor **
**Authorized Amsoil Dealer** Web Site hcvind.com | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
