cadillac parts
Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac Escalade, EXT and ESV Forum - 2007 and beyond
FAQ Donate Calendar Mark All Cadillac Forums Read
Cadillac Escalade, EXT and ESV Forum - 2007 and beyond Forum for discussions regarding the Escalade 2WD, AWD, EXT and ESV.
cadillac-escalade
Cadillac Forums: Towing a horse trailer
Old 05-14-08, 09:23 PM
tacklam tacklam is offline
Cadillac(s): Cadillac
Casino Cash: $310
I've searched the archives for an answer, but no luck so here goes -
I bought an '08 AWD and need to tow a 2 horse trailer (6900lbs loaded). I will install the prodigy brake controller but have questions about equalizer hitches and the autoride system. Since I don't like the chains in most equalizer hitch systems, I'm planning to purchase a sway control/ load equalizer hitch from Equal-i-zer (Progress Mfg in OR). After a long discussion with thier engineers today, they expressed that I need to disable the autoleveling airbags to gain the true benefit of any brand's equalizer hitch. The engineers expressed that when the airbags inflate, all of the weight is on the real axle; thus, making the equalizer hitch useless. The equalizer hitches are designed to place equal weight on the front and rear axle of the tow vehicle. In addition, it is impossible to correctly setup (level) the equalizer hitch with the airbags auto inflating.
Has anyone found a way to disable the airbags? Nothing in the manual... Service mgr at dealer is useless.
Another Q. - Do I need to add a fuse for the brake controller and another for the hotwire lead?
Thanks in advance.
Tom
  #2 (permalink)
Old 05-15-08, 06:25 AM
hcvone hcvone is offline
Zaino Distributor
Cadillac(s): 2008 SRX, (2) 2007 Escalade's, 2006 SRX
Casino Cash: $1560
Re: Towing a horse trailer
Welcome to the Forum. I have towed a 26 ft enclosed trailer all over, it weighs a little over 7k lbs, have not had any issues or problems and I tow thru the mountains, I am sure you can disconnect your rear air ride, just not sure you have to, or why you would want to, these trucks are made to tow.
Carl V.
**Authorized Zaino Distributor **
**Authorized Amsoil Dealer**
Web Site hcvind.com
24" Escalade wheels for sale, click on web site above, or look in the Cadillac Classified
  #3 (permalink)
Old 05-18-08, 02:56 PM
jdc jdc is offline
Casino Cash: $300
Tom,
I am pulling a large 2 horse slant trailer with my 07 EXT. loaded weight is about 7k. I have considerable experience with towing and see no reason to disable the air bags, in fact I found it helpful. Air bags are installed on many vehicles to assist with the load, I do agree that finding the correct drop receiver is a choir. Remember when towing, the tongue weight is really the critical factor and it should be about 10% of the loaded weight, (certainly within the vehicle parameters to carry). I think if you disabled the bags you would find the vehicle springs alone labored to carry the weight. As far as safety the big factor is the rated hitch installed from GM, it is only rated for 5k and should be 7.5k or better. The vehicle (or most) are pre wired for a controller, the dealer can make the connection under the hood at the fuse block with the factory wires, the brake controller wires should be next to the OBD port or the diagnostics plug. Be sure to buy a quality controller! I used a tecnosha P3.
R,
jdc
  #4 (permalink)
Old 05-19-08, 07:46 PM
91sonomast 91sonomast is offline
91sonomast's Avatar
Casino Cash: $1155
what GVWR is your vehicle rated? if you have the power brake boost then you have the heavy duty, if you have a big drum looking thing on your firewall you have the lower duty towing. but either way, idk if i would screw with the airride
  #5 (permalink)
Old 05-20-08, 12:33 AM
teutonictrio teutonictrio is offline
Casino Cash: $840
Originally Posted by jdc View Post
Tom,
R,
jdc
What? The hitch on the Escalade is Class IV, therefore it is good for up to 10k lbs - where are you getting the 5k rating?
Tags: , , ,
vB code is On
Censor is OFF
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac unlock navigation
earn
vacation travel
golf store
silver, gold, diamonds
Powered by vBulletin® Version 3.6.10
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods
