Cadillac Escalade, EXT and ESV Forum - 2007+ Forum for discussions regarding the Third Generation Escalade 2WD, AWD, EXT and ESV.
 | Cadillac Forums: How to convert your escalade to LED!
04-07-09, 05:49 PM
|  | Cadillac Owners Fanatic Cadillac(s): Cadillac Escalade | | Join Date: Dec 2008 Location: Alberta,Canada | | | Re: How to convert your escalade to LED! Quote:
Originally Posted by AMW23 Just wanted to thank everybody that contributed to this thread. I have over the weeked successfully converted my 07 esclade to LED.......boy what a change!!!
This is a 100% must-do-mod !!!!!!!!
If anybody needs help feel free to ask away......everything was relativly easy, other than the wedge lights in the front .... what a PITA! | What would be great if SOMEONE who has done this before would put together a light/lamp/bulb package for sale with all components...hint..hint  |
04-17-09, 11:15 AM
| | Cadillac Owners Member Cadillac(s): 2007 Escalade | | Join Date: Mar 2009 Age: 28 | | | Re: How to convert your escalade to LED! I just converted my truck to led and my lights on the inside flicker when they dim. Does anyone else have this issue or know how to fix it. |
04-17-09, 12:26 PM
| | Cadillac Owners Member Cadillac(s): 2007 Cadillac Escalade | | Join Date: Dec 2008 Age: 26 | | | Re: How to convert your escalade to LED! Mine do the same right be4 the are completely off.......doesnt bother me. |
04-19-09, 11:43 AM
| | Cadillac Owners Fanatic Cadillac(s): '07 Escalade ESV AWD | | | | | Re: How to convert your escalade to LED! Very cool info  ...a must do! Thanks... |
06-10-09, 04:19 AM
| | Cadillac Owners Member Cadillac(s): 08 Escalade | | Join Date: Jan 2009 Location: Los Angeles Age: 23 | | | Re: How to convert your escalade to LED! Quote:
Originally Posted by Quicksilver08 Thank you so much for your awesome guide
This is how everything turned out for me
Hope this helps for everyone else who would like to switch to LEDs
Personally I like it a lot
Would love to figure out what I could switch the DRL bulb with, but it seems like we are all on stuck on that | Did you change your fog lights into LED? what is the part number?
what did you do with front turn signal? |
06-12-09, 08:46 PM
| | Cadillac Owners Fanatic Cadillac(s): 2007 Cadillac Escalade, 2010 Chevrolet Camaro | | Join Date: May 2009 Age: 19 | | | Re: How to convert your escalade to LED! Can someone please post some more pictures? My friend installed some LEDs in his Maxima and they are blue. I don't want that "ricerish" look. All I want is white. Thanks! |
06-16-09, 02:48 PM
|  | Cadillac Owners Member Cadillac(s): 2007 Escalade | | Join Date: May 2006 Age: 20 | | | Re: How to convert your escalade to LED! Quote:
Originally Posted by Ahmedito Did you change your fog lights into LED? what is the part number?
what did you do with front turn signal? | the fogs are 8000k HIDs and the turn signals arent changed |
06-19-09, 07:01 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | Join Date: Mar 2008 Location: Tulsa, OK | | | Re: How to convert your escalade to LED! I have an 08 EXT and my tail light aren't LED. I want to replace the top 2 red lights and the bottom white reverse light.
Anyone know what 3 bulbs I need or which ones work the best. I have already done everything else with the LEDS from superbrightleds.com and am very happy so far!
Thanks in advance. |
06-27-09, 11:46 AM
| | Cadillac Owners Member Cadillac(s): ext | | Join Date: Jun 2009 Age: 19 | | | Re: How to convert your escalade to LED! love the lade Quicksilver08 looks great!
which LED'S did you use for the inside of the lade and the top headlight bulb? |
06-28-09, 12:09 AM
| | Cadillac Owners Member Cadillac(s): NONE | | | | | Re: How to convert your escalade to LED! Wow, awesome thread. |
08-02-09, 12:44 AM
| | Cadillac Owners Member Cadillac(s): 2007 Escalade | | Join Date: Jul 2009 Age: 26 | | | Re: How to convert your escalade to LED! So does everyones flicker when the lights dim out?
Cause thats not cool |
08-12-09, 12:52 PM
|  | Cadillac Owners Fanatic Cadillac(s): Cadillac Escalade | | Join Date: Oct 2007 Location: BC Age: 35 | | | Re: How to convert your escalade to LED! Hahaha I havent posted here for a while never thought my thread would take off like this. The leds in my escalade are still going strong and work fine, I still have no luck with the DRL either and have given up. Good luck everyone thanks for the positive feedback. |
08-14-09, 07:44 PM
| | Cadillac Owners Member Cadillac(s): 2007 Escalade | | | | | Re: How to convert your escalade to LED! Quote:
Originally Posted by roccos_van Hahaha I havent posted here for a while never thought my thread would take off like this. The leds in my escalade are still going strong and work fine, I still have no luck with the DRL either and have given up. Good luck everyone thanks for the positive feedback. | Thanks for the great thread. One question though...what was the procedure for changing the bulbs in the headlights? Did you have to remove the headlight assembly, or is there an easier way?
Thanks again. |
08-16-09, 12:30 PM
| | Cadillac Owners Member Cadillac(s): 2007 Black on Black Escalade LOADED | | Join Date: Aug 2009 Age: 33 | | | Re: How to convert your escalade to LED! Quicksilver,
Where did you end up finding out how to take the light housings off? How many LED's per bulb did you get for reverse, fog lights, and headlights? Would really appreciate some help. Your Slade looks NICE... |
08-17-09, 08:57 PM
|  | Cadillac Owners Fanatic Cadillac(s): Cadillac Escalade | | Join Date: Oct 2007 Location: BC Age: 35 | | | Re: How to convert your escalade to LED! Quote:
Originally Posted by ucsdsig Thanks for the great thread. One question though...what was the procedure for changing the bulbs in the headlights? Did you have to remove the headlight assembly, or is there an easier way?
Thanks again. | Go the the "HOW TO JOEY MOD YOUR HEADLIGHTS" thread, there is a tutorial link there on how to remove the headlights, it's really not that hard at all, but you need to completely remove the headlights to change the top bulb. | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
