Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac Escalade Forums > Cadillac Escalade, EXT and ESV Forum - 2007+
Cadillac Escalade, EXT and ESV Forum - 2007+ Forum for discussions regarding the Third Generation Escalade 2WD, AWD, EXT and ESV.
cadillac-escalade
Cadillac Forums: Second battery?
  #31 (permalink)
Old 11-09-08, 10:17 AM
Cadillac(s): Cadillac
View boss513's Photo Album
Casino Cash: $3035
Re: Second battery?
not the best pics but i spent around $225 a battery and less than 100 on wiring, you can take your truck to your local car audio shop and do this set up for a whole lot less
  #32 (permalink)
Old 11-10-08, 09:13 AM
Moderator
Cadillac(s): 2009,2008,2007 Escalade's, 2008,2006 SRX's
View hcvone's Photo Album
Casino Cash: $2900
Re: Second battery?
What battery did you get for $225.00, that is what my diesel boat batteries cost.
Carl V.
**Authorized Zaino Distributor **
**Authorized Amsoil Dealer**
Web Site hcvind.com
  #33 (permalink)
Old 11-15-08, 02:35 PM
Casino Cash: $3035
Re: Second battery?
i got a kinetik 1800 battery, these types of batteries are good for car audio, if i didnt get a kinetik i would of bought a optima yellow top.
  #34 (permalink)
Old 11-17-08, 09:25 AM
Moderator
Casino Cash: $2900
Re: Second battery?
Knew it must be special
  #35 (permalink)
Old 12-01-08, 06:48 PM
jrs05caddyext's Avatar
Cadillac(s): Escalade
View jrs05caddyext's Photo Album
Casino Cash: $7060
Re: Second battery?
Does anyone know if the setup above can be done to a 2009 EXT? Thanks
  #36 (permalink)
Old 12-02-08, 10:43 AM
Casino Cash: $7060
Re: Second battery?
ttt ttt
  #37 (permalink)
Old 12-02-08, 01:54 PM
RidingDirty's Avatar
Banned
Cadillac(s): 2007 Escalade ESV
View RidingDirty's Photo Album
Casino Cash: $3565
Re: Second battery?
I heard all gm trucks from 07 up can
  #38 (permalink)
Old 12-02-08, 02:38 PM
Casino Cash: $7060
Re: Second battery?
Thanks
  #39 (permalink)
Old 12-03-08, 06:38 PM
View v10boost's Photo Album
Casino Cash: $4875
Re: Second battery?
can someone post installation instructions?
Thanks
  #40 (permalink)
Old 12-05-08, 01:59 AM
2storm's Avatar
Cadillac(s): escalade ext
View 2storm's Photo Album
Casino Cash: $1160
Re: Second battery?
sounds simple. ground to frame/and or body, positive to starter.
i cant help but think, using an isolator would be best for charging.
I run a optima yellow in parallel in my car to help keep the audio pulsing
power draw from dimming the lights and having some key off reserve time.
i leave it in parallel with a quick connect so i can pull out second battery
to pass NHRA rules for 1/4 mile.
  #41 (permalink)
Old 12-05-08, 07:10 PM
Banned
Casino Cash: $3565
Re: Second battery?
why cant you just run a ground wire to the block and a positive wire to the other batteries positive post and connect them? Using the starter you are asking for trouble. One mishap and it touches the exhaust and you are thru.
Hooking it to the connection on the orginal battery is safe and works very well. Easy to get to and you dont have to get under the truck. Just run the cable along either the front or the back of the engine compartment, tire it up and ride on!!
Tell me what you all think about this? I can do it and make it look factory!!
  #42 (permalink)
Old 12-08-08, 09:33 AM
Moderator
Casino Cash: $2900
Re: Second battery?
The setup that I used for this post is the setup from the Tahoe Police truck, there are several ways to do the hookup, I just followed what the factory did.
  #43 (permalink)
Old 05-09-09, 11:13 PM
Cadillac(s): 2002 Escalade, 2005 EscaladeESV
View technobill's Photo Album
Casino Cash: $1125
Lightbulb Re: Second battery?
I have the dual battery setup in both 07's, it how the Police Tahoe's come from the factory. These are the parts you will need, one of each, plus a battery.
25825642 Cable
15888242 F Cable
14005061 Retainer
11509853 Screw
These parts should cost you about $116.00, it looks stock and you will should never have another battery issue. I have schematics but you can not really see much, e-mail me at carl@hcvind.com and I will send them to you
I have a 2005 EscaladeESV and would like to add a second battery. Is the physical space proximal to the firewall on the passenger side substantially greater in the '07s and following than previous generation Escalades? My concern is less with wiring specifics and more with obtaining a 'mounting tray' and brackets to secure an Optima Yellow Top.
I've plans for using the deep cycle Yellow Top in isolation from the main battery while using the ESV as a "Motor Home" i.e. parked overnight with separately powered auxilliary internal illumination. Am considering using the following to isolate the secondary battery while the engine is off, thus keeping the main battery untouched:
http://www.oznium.com/relay200/tech
Thanks,
Bill
  #44 (permalink)
Old 05-10-09, 04:20 AM
SFX Group's Avatar
Cadillac(s): none, looking at Escalade ESV
View SFX Group's Photo Album
Casino Cash: $3015
Re: Second battery?
This layout (assuming the relay has a 5th pole to as a common between the 2 batteries so the switch over is "car batt to 5th" then "aux batt to 5th", however this design will result in the AUX batt never being charged.
If it was me i would permanently wire the AUX to the system and then relay the car batt to turn it OFF when the ignition is OFF, this way both are used when driving (and means both charging) then only 1 (AUX) is on when not, as the relay would disconnect the main battery.
Many Thanks
Thanks,
Bill
  #45 (permalink)
Old 05-10-09, 06:10 PM
Casino Cash: $1125
Question Re: Second battery?
Many Thanks
1) If you note the pictures on associated tabs; There are only four posts.
2) If by "5th pole to as a common between the 2 batteries" you mean a common ground, they would share the chassis common ground.
3)
If by "5th pole to as a common between the 2 batteries" you mean a common connection between the positive terminals of the 2 batteries, that would be the relay itself. When the small post, to the left in the diagram labeled "This can be any 12 volt power source that is "live" when the engine is running" is supplying power, the relay connects the two large posts, connected respectively to the the positives of the two batteries and the second battery is charged through the positive terminal of battery one through the ground of battery two.
4) At what point would you "
permanently wire the AUX to the system"?
Thanks for the speedy response.
Any pre 2007 GMT800 (Tahoe, Denali, Escalade) owners who have physically placed a second battery in the open area proximal to the fire wall on the drivers side?
Thanks,
Bill
Tags: ,
battery
Censor is OFF
