Cadillac Escalade, EXT and ESV Forum - 2007+ Forum for discussions regarding the Third Generation Escalade 2WD, AWD, EXT and ESV.
 | Cadillac Forums: Long Or Short Tube Headers
01-07-08, 10:13 PM
| | Cadillac Owners Fanatic Cadillac(s): 07 Escalade, 07 EXT(Stolen),09 EXT | | Join Date: Oct 2006 Location: JERSEY | | | Long Or Short Tube Headers so im looking at either getting long or short tube headers for my EXT i was just trying to figure out which is better. what are to pros and cons or each, any input would be great thanks |
01-07-08, 10:46 PM
|  | Cadillac Owners Fanatic Cadillac(s): 07 AWD Escalade, 07 AWD Escalade ESV | | Join Date: Nov 2007 Location: Homestead, FL Age: 23 | | | Re: Long Or Short Tube Headers I got shorty headers in mine. For a V-8 they are better, i believe more low end power. |
01-08-08, 12:30 AM
|  | Cadillac Owners Fanatic Cadillac(s): Cadillac | | Join Date: Dec 2006 Location: Hollywood,FL | | | Re: Long Or Short Tube Headers Long tubes are the best for making HP  .Waiting on dynatech to make those for the 6.2. |
01-08-08, 08:23 AM
| | Moderator Cadillac(s): 2009,2008,2007 Escalade's, 2008,2006 SRX's | | Join Date: Apr 2003 Location: Huntingdon Valley, Pa. | | | Re: Long Or Short Tube Headers Shorties are a waste of money with the way the stock manifolds flow, shorties will give you 5-7 hp, not worth the cost, go long tubes or stay stock. The proper long tubes will give you the most hp 15-30, and the best low end torque on the dyno.
__________________ Carl V.
**Authorized Zaino Distributor **
**Authorized Amsoil Dealer** Web Site hcvind.com |
01-08-08, 09:49 AM
| | Cadillac Owners Fanatic Cadillac(s): 2007 Escalade EXT | | Join Date: Aug 2006 Location: South Carolina | | | Re: Long Or Short Tube Headers Are long tubes available yet? Also, will long tubes increase cabin volume? I have a cat back now and the sound is great at highway speeds. I am just concerned that headers will make the sund level uncomfortable on long rides. |
01-08-08, 10:30 AM
| | Moderator Cadillac(s): 2009,2008,2007 Escalade's, 2008,2006 SRX's | | Join Date: Apr 2003 Location: Huntingdon Valley, Pa. | | | Re: Long Or Short Tube Headers I think they are out for the 6.2. Any exhaust mod will add some noise, it's what happens when you increase power, having said that it sould not be much louder |
01-08-08, 10:42 AM
| | Cadillac Owners Fanatic Cadillac(s): 2007 Escalade EXT | | Join Date: Aug 2006 Location: South Carolina | | | Re: Long Or Short Tube Headers I just finished a search fr long tube headers. I can only find the shorty's for the 6.2. Has anyone alse had any luck? |
01-08-08, 10:47 AM
| | Moderator Cadillac(s): 2009,2008,2007 Escalade's, 2008,2006 SRX's | | Join Date: Apr 2003 Location: Huntingdon Valley, Pa. | | | Re: Long Or Short Tube Headers |
01-08-08, 01:34 PM
| | Cadillac Owners Fanatic Cadillac(s): 2007 Escalade EXT | | Join Date: Aug 2006 Location: South Carolina | | | Re: Long Or Short Tube Headers Quote:
Originally Posted by hcvone | Email sent. Thanks |
01-08-08, 05:52 PM
Originally Posted by hcvone Shorties are a waste of money with the way the stock manifolds flow, shorties will give you 5-7 hp, not worth the cost, go long tubes or stay stock. The proper long tubes will give you the most hp 15-30, and the best low end torque on the dyno.  | D3 claims a 21 hp increase using their short tube headers. I am confused. Can we get that type of gain with shorties?:  |
01-09-08, 09:07 AM
| | Moderator Cadillac(s): 2009,2008,2007 Escalade's, 2008,2006 SRX's | | Join Date: Apr 2003 Location: Huntingdon Valley, Pa. | | | Re: Long Or Short Tube Headers Make sure you are standing there before and after the install and the dyno run because 21 hp is not happening with shorties on an 07'  |
01-09-08, 10:13 PM
| | Cadillac Owners Fanatic Cadillac(s): 2007 Escalade EXT | | Join Date: Aug 2006 Location: South Carolina | | | Re: Long Or Short Tube Headers Please let us knw when your long tubes are available |
01-10-08, 09:20 PM
| | Cadillac Owners Member Cadillac(s): 07 Escalade | | | | | Re: Long Or Short Tube Headers Quote:
Originally Posted by 403HP D3 claims a 21 hp increase using their short tube headers. I am confused. Can we get that type of gain with shorties?:  | hcvone is correct, on a LS2 a good set of long tubes will make 15-25 the higher number would require high flow cats. Shorties might make 5 on a good day, no way will they make 21. D3 probably forgot to mention they got the 21 after the shorty install AND a very aggressive tune(ie. lean) on a cold day. |
01-11-08, 09:41 AM
Originally Posted by blownC6Z hcvone is correct, on a LS2 a good set of long tubes will make 15-25 the higher number would require high flow cats. Shorties might make 5 on a good day, no way will they make 21. D3 probably forgot to mention they got the 21 after the shorty install AND a very aggressive tune(ie. lean) on a cold day. | Thanks for your input. Do you know if any one is making long tubes for the 6.2? |
01-11-08, 01:42 PM
Originally Posted by 403HP Thanks for your input. Do you know if any one is making long tubes for the 6.2? | 403HP My comments on the ls1/ls2 and exhaust comes from my personal experience with these engines in Corvettes. Mr. Chevy did a pretty good with the factory exhaust so unless you make a big change(long tubes and high flow cats) you won't see much of a gain. I have no experience modding the ls3 in the Escalade but having looked at the exhaust manifolds on my 07, I see the same basic design as the Corvette and would expect similar results. Now for the hard part, finding someone making long tubes for an Escalade. There are several good header manufacturers of long tubes for the c5/c6 (Kooks, Stainless Works, LG to name a few). I know Stainless Works and Kooks both make headers for trucks so they might have something for the Escalade. Good luck in your search. | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
