Page 1 of 2 12 LastLast
Results 1 to 15 of 30
Thread: Check Engine Catalyst Problem Please Help Me
    nofinga911 is offline Cadillac Owners Fanatic
    Automobile(s): 07' White Diamond EXT
    Oct 2006
    QuEeNz Ny
    30
    475
    My check engine light is on and I checked the code with my predator and it says "P0430 Catalyst System Efficiency Is Below Threshold (Bank 2). Does anyone know what this means and how I can fix it?? I cleared the code but it keeps coming back.- Thanks
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    Re: Check Engine Catalyst Problem Please Help Me
    Quite simply, it means you need to replace the catalytic converter.
    The computer monitors the data from the pre catalyst O2 sensor and compares it to the data coming from the post catalyst sensor.
    One of the catalyst's jobs is "oxygen storage". It is hard to explain but the oxygen levels rise and fall rapidly in the exhaust manifolds but in the cat this is balanced out a bit, when the gasses flow out of the rear of the cat the dips and peaks of the pre cat sensor should flatten out, this indicates you have a healty catalylst.
    If the post cat sensor starts to mirror the dips and peaks of the pre-cat sensor then the computer knows it is not doing its job and the code will set.
    Many will tell you to do a dance, moving O2 sensors around and needlessly replacing them. Do it if you want but you won't get anywhere. One of the enable criteria for P0430 is that the O2 sensors have to pass their self diagnostics FIRST. If O2 sensor codes are set, the catalyst test won't run at all.
    Depending on the configuration of the exhaust you might have to buy the whole Y pipe with both cats.
    At any rate, on an Escalade the right side is bank 2. Be sure if you replace one... that it is the correct one.
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,299
    How many miles on your 07'?
  5. #4
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    I didn't notice this was on an '07.... as already asked... how many miles?
  6. #5
    Oct 2006
    QuEeNz Ny
    30
    475
    Quote Originally Posted by ewill3rd View Post
    the thing is still pretty much brand new...no more then 15,000
  7. #6
    Oct 2006
    QuEeNz Ny
    30
    475
    what should I do? Take it to service? I cleared the check engine light again last night and it never came back on...will they still be able to tell if i bring it to service? Also could any of this be caused from using octane booster, my throttle body spacer that i recently installed, or the fact that i programmed my car with a predator programmer?
  8. #7
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,285
    If you go in there with a story like that they're going to make your wife a widow and your house into a dung heap.
    Don't mess with Binky Bear!
  9. #8
    ncCADDYman is offline Cadillac Owners Member
    Automobile(s): 2008 CTS (hopefully soon)
    Sep 2007
    Charlotte, NC
    36
    86
    you didn't run over anything and damage the o2 sensor or cat did u?
  10. #9
    Apr 2003
    13,299
    It maybe the octane booster depending on how much you used. It's not the Preditor
  11. #10
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    You could have done some damage to the cat with all that. Most likely the additive.
    No need to give the dealer all that info.
    Wait for the MIL to come on (check engine light) and take it in, act dumb and tell them the check engine light just came on.
  12. #11
    SFX Group's Avatar
    SFX Group is offline Cadillac Owners Enthusiast
    Automobile(s): None at the moment
    Aug 2007
    Cambridge, ON
    44
    561
    Heres the basics, the CATS are coated in platinum, this is why there expensive, there are substances you can pass over them to remove the coating, one is fuel this is why you should never turn the engine over more than about 3 seconds if it doenst fire as it pumps neat fuel through and wipes the cats out, hence they never do there job.
    So there will be other substances to do the same thing, your need to do research,
    Basic is remove anything you put on, or dont tell the dealer it should just show up as a "bad" CAT and be replaced.
    CATS should last about 10 years (assuming they dont corrode first).
    Many Thanks
    Ashley
  13. #12
    Oct 2006
    QuEeNz Ny
    30
    475
    Quote Originally Posted by hcvone View Post
    but how can it be the octane booster? I dont really understand that
  14. #13
    Apr 2003
    13,299
    Quote Originally Posted by nofinga911 View Post
    The additives may have damaged the cat.
  15. #14
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    Pouring chemicals not recommend by the manufacturer in the tank can affect the catalyst material and render it useless.
    Sort of like pouring urine into beer.
    Sure it says beer on the label... but do you want to drink it?
  16. #15
    TSS's Avatar
    TSS is offline Cadillac Owners Connoisseur
    Automobile(s): 07 Lade & 06 SRX (Gone); 2010 Enclave CXL; 2010 MKS Ecoboost
    Jun 2006
    3,673
    Be sure to program vehicle back to stock w/ the preditor before you bring it in.
  • You may not post replies
