Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac Escalade Forums > Cadillac Escalade, EXT and ESV Forum - 2007+
Cadillac Escalade, EXT and ESV Forum - 2007+ Forum for discussions regarding the Third Generation Escalade 2WD, AWD, EXT and ESV.
cadillac-escalade
Cadillac Forums: video tutorial
  #31 (permalink)
Old 02-08-09, 08:50 PM
murphy's Avatar
Cadillac(s): Cadillac Escalade
View murphy's Photo Album
Casino Cash: $6655
Re: video tutorial
I tried to but it doesn't work..I play with it some more when I can..
  #32 (permalink)
Old 02-11-09, 03:14 AM
Cadillac(s): '08 Escalade
View CharlieC's Photo Album
Casino Cash: $485
Re: video tutorial
You need the Divx plug-in to play them. Have you guys turned your pop-up blockers off and tried to play them? The Divx plug-in will prompt you to load if you don't have it.
Charlie
  #33 (permalink)
Old 02-11-09, 11:36 AM
Cadillac(s): 2007 Cadillac Escalade
View AMW23's Photo Album
Casino Cash: $2755
Re: video tutorial
Today seems as if it will be the last day mother nature grants me time to do my lock pick.
I would really appreciate if somebody could upload the video or somehow get me instructions on the process to taking the trim / navi out.
The first 3 videos work from the site that was previously listed but of course, the 4th one the one I need , does not work and gives me an error.
Please, thanks a lot guys!!
  #34 (permalink)
Old 02-11-09, 02:00 PM
View nixonride's Photo Album
Casino Cash: $3270
Re: video tutorial
Not sure what to tell you I can watch the others too but I also get the error on the one you need. I can try to guid you through it.
1st - All the wood and metal pieces are attached via clips that just take some pressure to pullout. If you have a dash removal tool then you are in luch and it is pretty easy. If not you have will probably have to use a small screw driver. I would start just to the right of the steering wheel because that is a spot where you should be able to grab with your fingers and pull. Once it comes out just slowly work your way around the middle.
The pice on the far right that spans accross the dash will have to some out as well as the center console piece that has the cup holders. To get that up I just grabbed in the middle of the cup holders and pulled up. The piece that goes from around the heat controls and meets the center console is kind've clipped together. You have to have the whole top loose to get them apart. To do this pull the top of wood surrounding the radio towards you and slowly lift up. be carful not to break the tab or tab older.
Basically the piece that goes around the radio has two male tabs that stick out (one on each side) and the center console piece has two square slits that they sit into. The male pieces have little tabs on the end so by moving the top towards you the tabs should be pushed far enough forward for you to lift it out. Make sure that when you do this both pieces are completly free so that they can both move some.
Once these pieces are out you have like 8 7mm screws holding the nav, hvac, and all that in. you will have to take all the screws out so that the nav is free. I disconnected all the other stuff so that I could set them asside and not scratch the faces of them because it is hard to fit the lockpick back there.
I placed my lockpick under the air vent closest to the driver and ran the wires up through the back where the factory harness comes from. It is a hard task but that way if I have issues I can take the bezel off and have access to the lockpick with out pulling the Nav and everything again. Good luck with the install and let me know iof you have any other questions.
  #35 (permalink)
Old 02-11-09, 05:19 PM
Casino Cash: $2755
Re: video tutorial
TY SOOOO MUCH!!!
Will try!!!!
  #36 (permalink)
Old 02-11-09, 06:23 PM
Cadillac(s): Escalade
View petercoolz's Photo Album
Casino Cash: $1985
Re: video tutorial
Which videos are the one that work? There are several links in this thread, and I've been through all of them, installed the divx players, and I cannot get anything to play. The source videos all point to divx videos from yourgmsolutions.com, which no longer exists.
Tags: ,
tutorial, video
Censor is OFF
