07 D/S Mirror Vibration
Results 1 to 12 of 12
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, 07 D/S Mirror Vibration in Cadillac Escalade Forums; Mirror still vibrates even after fix. Showed dealer excessive play with mirror, said normal, even others on lot do not ...
    jaycough is offline Cadillac Owners Fanatic
    Automobile(s): 2007 esv
    Feb 2006
    cape coral,fl
    160
    Mirror still vibrates even after fix. Showed dealer excessive play with mirror, said normal, even others on lot do not do. While I fix my windnoise which they said they fixed, I want to do adjust the mirror face attachments springs. Can someone attach a PDF of TSB as well as instructions how to remove mirror face (not the same as my 2004. thanks
    gforceext is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Mar 2007
    139
    Re: 07 D/S Mirror Vibration
    mine vibrates also.
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,289
    Mine made some movment until I had my tires road force balanced, now none
    Feb 2006
    cape coral,fl
    160
    Quote Originally Posted by hcvone View Post
    yep, that's another problem, at 75 mph, dealer says over speed limit and won't fix. Dealer sucks (VAL WARD FORT MYERS), next close one is 45 miles.
    Had Phantom wipe, 3 visits, got fixed when I said not going anywhere until they could explain information on GM Service Website.
    DLH
    DLH is offline Cadillac Owners Fanatic
    Nov 2006
    140
    Quote Originally Posted by jaycough View Post
    I have the exact same problem with my DS mirror and am told the tech cannot see the vibration. I suppose they are more focused on the lag in the transmission and whether they will get run over when they pull into traffic..The vibration is VERY annoying on long trips. I was told the last time that if they cannot detect the vibration then a goodwill exchange will be done. Stay with it cos you and I are not crazy!
    AWF_AXIS's Avatar
    AWF_AXIS is offline Cadillac Owners Fanatic
    Mar 2006
    Truckee, CA
    364
    You'll get used to it after a while. I no longer notice it, since I can no longer focus on anything without glasses...
    Dave
    DLH
    Nov 2006
    140
    Quote Originally Posted by AWF_AXIS View Post
    Dave
    NO WAY! Especially, having paid what I did.
    jayzlade is offline Cadillac Owners Member
    Automobile(s): 2007 Cadillac escalade,
    Mar 2007
    hawaii
    30
    What kind of noise is it? Mine is making a rattling noise also. I think it is from the d/s door. When I turn off my radio you could hear some sort of rattle coming from the d/s door or mirror. Its my first caddy, you would think a 60 -70 dollar truck would be built better. Mine has all kinds of rattles and lose fitting interior parts. My escalade has only 2500 miles on it. My 05 meredes has 40000 miles, 19'' rims and lowered and not one single rattle. Anyone having same issues? Should i take it bake to the dealer? O one more thing when I start my truck in the mornning or when its been sitting for a while it makes some kind of pinging noise, its kind of loud. My friend thought it was diesal.
    cadymon's Avatar
    cadymon is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac escalade esv07
    Jan 2007
    socal
    294
    i did notice the the mirror shaking a bit and wind noise coming from the driverside door too.
    Feb 2006
    cape coral,fl
    160
    I have a rattle also, haven't had time to figure whether l/f or l/r door. also in AM have noise that goes away after 1/2 mile. sounds like knock, etc....
    right now the freaking mirror and wind noise drivimg me crazy
    Mar 2007
    hawaii
    30
    Let me know if you find out what the rattling is. Are you going to bring it back to the dealer for the engine noise?
    Dwhoelse's Avatar
    Dwhoelse is offline Cadillac Owners Member
    Automobile(s): 01 Seville STS
    Aug 2006
    MD-DC-VA
    14
    Those of you hearing a rattle coming from your door may want to check the wood trim (if installed). I thought I had a blown speaker but the sound could also be heard when the radio was off. After listening carefully, it was coming from directly behind the wood trim, and when pressed, the rattle went away. I haven't figured out a solution yet so if anyone else has solved this, please post.
  15. Remove Advertisements
