Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Forum for discussions regarding the First and Second Generation Escalade 2WD, AWD, EXT and ESV.
 | Cadillac Forums: 2002 Escalade Rotors and Brakes
01-29-07, 11:33 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | 2002 Escalade Rotors and Brakes What brand brake pads and rotors would you suggest I use for my 2002 Escalade? |
01-30-07, 07:41 AM
| | Cadillac Owners Master Cadillac(s): 2009,2008,2007 Escalade's, 2008,2006 SRX's | | Join Date: Apr 2003 Location: Huntingdon Valley, Pa. | | | Re: 2002 Escalade Rotors and Brakes Not sure if the 02's came with ceramic pads like the 03's did, those pads work very good, last a long time, and do not make dust. The stock rotors are good, also Baer rotors, SSBC rotors are another good choice |
01-31-07, 08:40 PM
| | Cadillac Owners Member | | | | | Re: 2002 Escalade Rotors and Brakes Stock rotors are fine but pricey. I use "Quality" from my local chevy dealer. Never a problem.
Use OEM ACDelco pads for least dust, no noise, and no comeback complaints. I've tried them all.
If you're asking this question, then perhaps the brakes aren't being serviced correctly. If the metal pad support backet is corroded on any of the 4 corners, you will have problems. The pads will not apply and release correctly. Properly clearanced brackets will allow you to slide the pads in and out with little or no effort, which means they will work properly. I've yet to find another mechanic who can do this right besides me.
If your not getting 45k miles or better on front pads, fire your mechanic. If your not getting 50k on the rear fire your mechanic.
Or, educate him/her. |
01-31-07, 11:08 PM
|  | Super Moderator Cadillac(s): 2002 Aspen White Escalade | | Join Date: Feb 2004 Location: Bayside, NYC Age: 24 | | | Re: 2002 Escalade Rotors and Brakes The 2002s do have the ceramic pads as well.
__________________ ~Steve |
01-31-07, 11:54 PM
| | Cadillac Owners Member | | Join Date: Dec 2005 Location: pittsburgh | | | Re: 2002 Escalade Rotors and Brakes i put new front brakes and rotors on and my car still has this thumping feeling when i have to brake hard coming down a hill its a 02 |
04-19-07, 12:54 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: 2002 Escalade Rotors and Brakes Quote:
Originally Posted by kevinp What brand brake pads and rotors would you suggest I use for my 2002 Escalade? | I used the 2nd grade pads from Autozone and they work great. |
04-20-07, 01:35 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 2003 Escalade | | Join Date: Jul 2005 Location: Milwaukee Age: 30 | | | Re: 2002 Escalade Rotors and Brakes hawk ceramic pads here |
04-20-07, 02:27 PM
| | Cadillac Owners Fanatic Cadillac(s): 02 Escalade | | Join Date: Apr 2004 Location: Austin TX | | | Re: 2002 Escalade Rotors and Brakes I also have the Hawk pads with the Baer Eradispeed +2 14" rotors. Great combo with larger wheels.
Walter |
04-20-07, 02:39 PM
| | Cadillac Owners Master Cadillac(s): 2009,2008,2007 Escalade's, 2008,2006 SRX's | | Join Date: Apr 2003 Location: Huntingdon Valley, Pa. | | | Re: 2002 Escalade Rotors and Brakes Quote:
Originally Posted by LacCrusinSky i put new front brakes and rotors on and my car still has this thumping feeling when i have to brake hard coming down a hill its a 02 | Get your rotors turned and the thumping will stop.  | | Cadillac Discussion Tools | | |
Censor is ON | | | |
