Results 1 to 3 of 3
Thread: Need Help with my Corsa Muffler?? will it fit?
    Mar 2003
    172
    I Bought a Corsa muffler from a guy here on this forum (Just the muffler),
    I Went to install it today & Now i found out that my EXT has Duel inlet & duel outs on the stock muffler, The corsa in single in/Single out
    The guy at the muffler shop said that if i make a Y-Pipe to make my stock pipe(from the cat to the muffler) that it would make too much back pressure & make the Check Engine Light come on because of the o2Sensors?
    is this true?
    dose corsa mufflers come with duel inlet/outlet pipes for the 6.0? or is the muffler i have made for a 5.3? i am very confused now & not sure what to do PLEASE HELP,
    Do you guys have any pics of your installs?
    and/or your Corsa Muffler, the one i got seems to be like a strait pipe It looks like it has no Baffels & it dosen't say corsa on the muffler? dose yours look like this?
    ANY SOUND CLIPS?
    thanks I NEED HELP ASAP!!.
    DOSE YOUR MUFFLER SAY CORSA anywhere on it?
    mine don't?
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,299
    Re: Need Help with my Corsa Muffler?? will it fit?
    You have a Corsa muffler for a 6.0, it appears that Corsa uses a "Y" pipe into one muffler looking around at pixs on the internet, I will check my Corsa system when I get home on Monday. I have had no check engine lights in 12,000 miles since I installed it, and it has much less backpressure than stock, you can tell that by how quickly it winds through the gears.
    Mar 2003
    172
    can you send me some of the pictures your've seen on the net,
    i've been looking for Corsa Installs & Pictures all day & havn't founf anything.
    thanks.
  • You may not post replies
