Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Forum for discussions regarding the First and Second Generation Escalade 2WD, AWD, EXT and ESV.
 | Cadillac Forums: Avic D2 video while driving.
12-16-06, 03:34 PM
|  | Cadillac Owners Fanatic Cadillac(s): 02 Cadillac EXT | | Join Date: Sep 2006 Location: Philly | | | Avic D2 video while driving. I just got done looking through a ton of old posts and can't find my answer so forgive me for asking the same question. I have a Pioneer Avic D2 & a seperate DVD player. I have it hooked up so I can see the video on the Avic & the dvd player. I even have the ground wire to the parking brake but when I drive I can't watch the video on the Avic... Anyone have an easy fix? |
12-16-06, 04:28 PM
|  | Cadillac Owners Fanatic Cadillac(s): 08 Z06 (543rwhp-521rwtq)05 CTS-V (???rwhp-???rwtq) | | Join Date: Jul 2005 Location: S. California Age: 28 | | | Re: Avic D2 video while driving. i think you have to hook it up to a swicted groung and on and off twice.give that a try,if it doe's not work i can find out from my installer on monday. |
12-16-06, 06:04 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2006 Cadillac Escalade EXT | | Join Date: Sep 2003 Location: New Jersey Age: 24 | | | Re: Avic D2 video while driving. i think something has to be soldered or something like that.. |
12-16-06, 10:02 PM
|  | Cadillac Owners Connoisseur | | Join Date: Sep 2006 Location: Poway CA Age: 42 | | | Re: Avic D2 video while driving. here is what I did. on your Avic main harness you have a empty pin. you need to insert wire in there and ground it along with brake wire. it will unlock everything on your nav. |
12-17-06, 08:13 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 02 ESCALADE | | Join Date: Apr 2005 Location: CALIFORNIA | | | Re: Avic D2 video while driving. I got a speed sensor and parking brake lead. I grounded both of them, disables it all. Thats on an AVIC-N3. |
12-17-06, 08:39 PM
| | Cadillac Owners Member | | | | | Re: Avic D2 video while driving. GM Geek has the correct answer for the D2 bypass. |
12-17-06, 11:27 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2006 Cadillac Escalade EXT | | Join Date: Sep 2003 Location: New Jersey Age: 24 | | | Re: Avic D2 video while driving. do you ground them both to the same place or to separate grounds? also should they be put on a switch so they are only grounded when switched or does it not make a difference? lastly.. can it be grounded to the ground in the wire harness or should it be separate? thanks |
12-18-06, 02:17 AM
| | Registered User | | Join Date: Apr 2004 Location: Toronto Ontario, Canada Age: 32 | | | Re: Avic D2 video while driving. AVIC-N2 lockout bypass: Underneath the MAIN unit (not the hideaway) is a small silver sticker, peel this back. There are two contacts with the label "R197". Drop a bit of solder between these to connect them. Also, you must ground the Parking Brake wire. |
12-19-06, 04:58 PM
|  | Cadillac Owners Fanatic Cadillac(s): 02 Cadillac EXT | | Join Date: Sep 2006 Location: Philly | | | Re: Avic D2 video while driving. Quote:
Originally Posted by gm_geek here is what I did. on your Avic main harness you have a empty pin. you need to insert wire in there and ground it along with brake wire. it will unlock everything on your nav. | This is probably a dumb question but when you say ground it you mean just ground it to metal or to a screw? I'm sure the answer is yes but I just want to be extra sure so I don't fry the radio. Thanks for all the help guys! |
12-19-06, 06:40 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 02 ESCALADE | | Join Date: Apr 2005 Location: CALIFORNIA | | | Re: Avic D2 video while driving. Quote:
Originally Posted by RichieRich This is probably a dumb question but when you say ground it you mean just ground it to metal or to a screw? I'm sure the answer is yes but I just want to be extra sure so I don't fry the radio. Thanks for all the help guys! | There is a wiring harness that goes into the back up your deck. There is a ground there (Black Wire), connect it here. And yes, grounding is also to metal, screw, etc. |
12-20-06, 02:29 AM
|  | Cadillac Owners Fanatic Cadillac(s): 02 Cadillac EXT | | Join Date: Sep 2006 Location: Philly | | | Re: Avic D2 video while driving. I did it.. Something didn't go right or I have to reset something because now I no longer have the option to select AV on my headunit... The nav, CD, Radio & XM all still work fine but AV isn't highlighted anymore so I can't select it. |
12-20-06, 10:08 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 02 Escalade/ 04 Escalade EXT | | Join Date: Mar 2006 Location: Vancouver, WA Age: 27 | | | Re: Avic D2 video while driving. Quote:
Originally Posted by RichieRich I did it.. Something didn't go right or I have to reset something because now I no longer have the option to select AV on my headunit... The nav, CD, Radio & XM all still work fine but AV isn't highlighted anymore so I can't select it. | Do you have an option to select "set up memory"?? If so, play around with that, because on my Kenwood, it can lock and unlock the AV. Hope that helps. |
12-20-06, 06:04 PM
|  | Cadillac Owners Fanatic Cadillac(s): 02 Cadillac EXT | | Join Date: Sep 2006 Location: Philly | | | Re: Avic D2 video while driving. I figured it out.. It was all done right, I just had to go into the settings & select AV... Anyway, It's all good, thanks for the help everybody. |
12-20-06, 07:40 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 02 Escalade/ 04 Escalade EXT | | Join Date: Mar 2006 Location: Vancouver, WA Age: 27 | | | Re: Avic D2 video while driving. Glad you figured it out.
My two headrest monitors are connected to my double din that I just got installed. ANyways, the other day, all of a sudden, both of my headrest monitors read "NO SIGNAL" and the screen was blank. I was like, oh shit, something must've came loose.
Well, i played around in the settings too, and I had to select the AV mode, and it came back up. lol. I was freaking out for a bit, but everything was cool all along.  |
05-09-08, 02:06 AM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Avic D2 video while driving. hey i have a pioneer n2 navigation too. I need some istall help with it. Like what kind of wires and everything i need and like how to get the bose sound bypass. I need to know exactly what to get and what to do. THis is my first install, but i'm curious to see if i can actually do it myself for once. I have taken them out but never actually put them in. Howe difficult is it to do it. Fyi i have a 2002 escalade with a bose system. Also where should i put the brain in the car? | | Cadillac Discussion Tools | | |
Censor is ON | | | |
