"Normal" Leaks?
Results 1 to 10 of 10
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, "Normal" Leaks? in Cadillac Escalade Forums; I own a 99 Escalade with fluid leaking from almost every component that holds fluid. The truck has 94,000 mi ...
    skides1's Avatar
    skides1 is offline Cadillac Owners Enthusiast
    Mar 2004
    Seattle
    508
    Unhappy"Normal" Leaks?
    I own a 99 Escalade with fluid leaking from almost every component that holds fluid. The truck has 94,000 mi on it. ALL recomended maint. has been performed before it was due and in some cases doubled. Leaky intake manifold, rear end seals rear main once-now its leaking again water pump etc. etc. My question is: is a certain amount of leakage "normal" all of the items at the dealer I'm beginning to wonder if there is a Balance-vibration issue with every component of the vehicle. HELP! Budget repair advice greatly appreciated.
    99 SKALAID's Avatar
    99 SKALAID is offline Cadillac Owners Fanatic
    Feb 2004
    california
    37
    376
    Re: "Normal" Leaks?
    Quote Originally Posted by skides1
    my 99 has 100K and has no leaks from anywhere
    skides1's Avatar
    Mar 2004
    Seattle
    508
    Re: "Normal" Leaks?
    Quote Originally Posted by 99 SKALAID
    Do you drive it hard or just cruise e.g : cross country mnts?
    Partiers_com is offline Cadillac Owners Member
    Feb 2004
    New Castle, PA USA
    44
    64
    Re: "Normal" Leaks?
    We have what seems to be a leak from the front end differential. It's an oily lubricant fluid with a very sweet smell. There are drips coming off the drive shaft near the front gear box...where the driveshaft meets the front axle. Any ideas? Has anybody else leaked from there?!
    Thanks,
    Kevin
    '99 Escalade
    99 SKALAID's Avatar
    Feb 2004
    california
    37
    376
    Re: "Normal" Leaks?
    i tow my mustang and camaro with it quite frequently. This past weekend, i did a 680 mile trip. had no problems... only complaint was that after sitting in the truck for 3+ hours my butt and back were SOOOO hot from the heated seats, but i just turned them off and was all good then
    Feb 2004
    New Castle, PA USA
    44
    64
    UnhappyFront pinion seal leak
    Our problem is most likely the front pinion seal behind the front yolk.
    The oil we are dripping is most likely gear box oil. Smells just like 85-90W gearbox oil. Probably need to drop the driveshaft and replace the seal.
    Anybody ever have this problem, too?
    Thanks,
    Kevin
    '99 Escalade
    99 SKALAID's Avatar
    Feb 2004
    california
    37
    376
    Re: Front pinion seal leak
    Quote Originally Posted by Partiers_com
    Thanks,
    Kevin
    '99 Escalade
    that is a pretty common problem for gm, also in the front end are axle seals, and those leak frequently as well.... mine are leaking slightly
    skides1's Avatar
    Mar 2004
    Seattle
    508
    Re: "Normal" Leaks?
    Bump. I saw a user asking.
    skides1's Avatar
    Mar 2004
    Seattle
    508
    Re: "Normal" Leaks?
    Intake gasket leakage anyone?
    CADI05 is offline Cadillac Owners Member
    May 2004
    6
    SmileRe: "Normal" Leaks?
    I just fixed my intake gasket leak...I have a 99 lade and I was really worried it would lead to bigger problems so I got it fixed....$400.
    if you love your lade and want it to last..you do what you got to do to keep it in working condition...
    good luck
  13. Remove Advertisements
