Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Forum for discussions regarding the First and Second Generation Escalade 2WD, AWD, EXT and ESV.
 | Cadillac Forums: Check Engine light just came on, can I reset it?
11-07-06, 07:42 PM
|  | Cadillac Owners Fanatic Cadillac(s): 02 Cadillac EXT | | Join Date: Sep 2006 Location: Philly | | | Check Engine light just came on, can I reset it? I have an 02 EXT... I just hit 55,000 miles & the check engine light came on. My wife has a Suzuki Grand Vitara & the exact same thing happened at 55,000 miles. It was easy to reset. I'm figuring this is the same deal but how do I reset it, or can't I? |
11-07-06, 07:48 PM
| | Cadillac Owners Fanatic Cadillac(s): 2004 Escalade black w/ navi | | | | | Re: Check Engine light just came on, can I reset it? you can reset it, but the light will probably come back fixing the problem would be a better idea. your friends car is japanese there is a big difference. |
11-07-06, 07:52 PM
|  | Cadillac Owners Fanatic Cadillac(s): 02 Cadillac EXT | | Join Date: Sep 2006 Location: Philly | | | Re: Check Engine light just came on, can I reset it? I guess what I was getting at is, does the light only go on when there is a problem or is it automatic at certain mileage? I figured it was just a dummy light to go on to remind you to service the vehicle every so often just like the change oild light every 3000 miles. |
11-07-06, 08:01 PM
|  | Super Moderator Cadillac(s): 2002 Aspen White Escalade | | Join Date: Feb 2004 Location: Bayside, NYC Age: 24 | | | Re: Check Engine light just came on, can I reset it? It only comes on when there is a problem. If you have Onstar, ask them to do a remote diagnostic check.
__________________ ~Steve |
11-07-06, 08:09 PM
| | Cadillac Owners Fanatic Cadillac(s): 2003 Diamond White ESV | | Join Date: Oct 2006 Age: 28 | | | Re: Check Engine light just came on, can I reset it? turn the key on and pull the "pcm batt" or "pcm ign" fuse (not sure wich one it is so just pull both) wait about 30 sec and then pull the key and replace the fuses.
80% of the time its a sensor going out. every one in a blue moon though it does come on for something crazy and there really is nothing wrong. |
11-07-06, 08:13 PM
| | Cadillac Owners Fanatic Cadillac(s): 2004 Escalade black w/ navi | | | | | Re: Check Engine light just came on, can I reset it? its prob a 2 cent oxygen sensor. just go to auto zone theyll scan it free and tell u what the problem si |
11-07-06, 09:05 PM
|  | Cadillac Owners Connoisseur Cadillac(s): Escalade EXT | | Join Date: Aug 2003 Location: 858, SoCal, Kuwait Age: 26 | | | Re: Check Engine light just came on, can I reset it? Quote:
Originally Posted by SUX2BU turn the key on and pull the "pcm batt" or "pcm ign" fuse (not sure wich one it is so just pull both) wait about 30 sec and then pull the key and replace the fuses.
80% of the time its a sensor going out. every one in a blue moon though it does come on for something crazy and there really is nothing wrong. | Wow never knew that, good info if it works |
11-07-06, 10:40 PM
|  | Cadillac Owners Fanatic Cadillac(s): 02 Cadillac EXT | | Join Date: Sep 2006 Location: Philly | | | Re: Check Engine light just came on, can I reset it? Fast66 I'm gonna try that in a few minutes... or as soon as I find the fuses you're talkin about. I have no idea where the fuse pannel is... But great tip! Thanks! | | Cadillac Discussion Tools | | |
Censor is ON | | | |
