McGaughy's 2/3 drop deluxe Lowering Kit on my ESV pics! - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, McGaughy's 2/3 drop deluxe Lowering Kit on my ESV pics! in Cadillac Escalade Forums; Originally Posted by Bagmo16 Thanks for the technical explanation.....nice first post aswell ....was the grinding required because of your Rim ...
  1. #16
    SUX2BU is offline Cadillac Owners Fanatic
    Automobile(s): 2003 Diamond White ESV
    Oct 2006
    35
    287
    Re: McGaughy's 2/3 drop deluxe Lowering Kit on my ESV pics!
    Quote Originally Posted by Bagmo16 View Post
    Thanks for the technical explanation.....nice first post aswell ....was the grinding required because of your Rim size or is it required on all applications? Also as I read about lowering, there seems to be two schools on the front end....the spindle or the control arm or a combination of both....And what about the rear?
    Thanks
    You have to grind the lower ball joint bolt/nut to put the sock 17's back on.
    The rear is springs and lower shock mounts relocation brackets.
    BTW i reccomend you only use the spindle kits for the front. The lowering key's will max out your alignment specs. my friend couldn't get his Lade aligned within specs because of the lowering keys.
  2. #17
    Bagmo16 is offline Cadillac Owners Member
    Automobile(s): 02 Escalade
    Jan 2007
    All over
    45
    Thanks for the advice....Hope to eventually get it together and post some pics of the job and completion.
  3. #18
    PhatBoy is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Feb 2007
    CoolRe: McGaughy's 2/3 drop deluxe Lowering Kit on my ESV pics!
    Thanks
    I have heavy duty 18s for winter [lots of skiing] with Nitto Terra Grapler tires [awesome - plug] and 22s with very poor tires for summer. The 18s have a very thick inner lip on the rim so I had to grind the lower ball joint nut; as described. I bought the 18s 'cos I was told the stock 17s dont work with the kit and ended up grinding anyway, but it seems with grind I could have kept the stock 17s now. 18s were nice anyway. And the nicest thing? I kept both sets of wheels for the new 07 Escalade when I traded the old Denali in.
  5. #19
    icaddy is offline Cadillac Owners Fanatic
    Sep 2012
    43
    137
    sorry for digging into a very old thread, and could not see pictures
    anyway, I was planing to do the same thing on my 05 Escalade Base. Just wondering if this kit will also fit base model? The McGaughy's part number is 33047 (Deluxe lowing kit).
    Also I did a lot search, seems the lowest price is around $480. Anybody got a good deal recently?
    thank you
  6. #20
    TLMC is offline Cadillac Owners Member
    Automobile(s): 2011 Escalade 1969 ss396 chevelle 1967 GTO
    Nov 2011
    BOYNTON BEACH,FL
    63
    76
    I used the same kit and you don't have to bend the sensor rods. gently pull off one end and cut the rod at the grove. glue the end cap back on and this trick,s the computer . I did not use the 2 inch keys for the front, I used the factory keys just lowered and got a perfect alignment.
  7. #21
    Sep 2012
    43
    137
    Quote Originally Posted by TLMC View Post
    TLMC, many thanks. Still seems a little bit tricky to me. Do you have step by step instruction that can be shared with me?
  8. Remove Advertisements
