Results 1 to 9 of 9
Thread: steering stabilizer
    96ss#80 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Sep 2006
    3
    steering stabilizer
    I need help finding a steering stabilizer that will fit an 02 lade with stock ride height. I called skyjacker and superlift and they both said they didnt have anything that would fit. I have done searches on here and a few people said they have used them. anyone have a part number and some pics of the part installed on a all wheel drive 02-06?
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,299
    Re: steering stabilizer
    Have you had your front end looked at by a shop? You might have something that needs to be replaced. There are several that will work, although most companies do not list Caddy for applications. Look at the 1500 pickup trucks I believe the front end is the same
    Fabtech steering stabilizers
    EXTadic is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Ext (sable black) and 1966 chevelle
    Feb 2006
    So Cali (818)
    47
    255
    I found out the problem with installling the stabilizer is the space reqiured is insufficient unless you install a lift kit first. Otherwise there isn't enough room for the bracketry and stabilizer shock.
  5. #4
    fast66's Avatar
    fast66 is offline Cadillac Owners Connoisseur
    Automobile(s): Escalade EXT
    Aug 2003
    858, SoCal, Kuwait
    33
    2,294
    steering stablizer, what for??
  6. #5
    Feb 2006
    So Cali (818)
    47
    255
    Quote Originally Posted by fast66 View Post
    well some people have experienced some "groove steer" and premature steering component wear commonly associated with big wheels. If you had these problems on a 4x4 with big tires you would install a steering stabilizer to correct this issue. Then why not an escalade with 24's or 26'. I think it's a good idea.
  7. #6
    fast66's Avatar
    Aug 2003
    858, SoCal, Kuwait
    33
    2,294
    Quote Originally Posted by EXTadic View Post
    Okay Im down to experiment with this.
    If anyone has more info, let me know.
  8. #7
    Nov 2004
    46
    Did you ever find one that would work???? I have the same problem.
  9. #8
    jnrsesv is offline Cadillac Owners Enthusiast
    Automobile(s): '05 ESV Platinum
    Feb 2010
    Sunny South Carolina
    916
    Man talking about a "raised from the dead" thread.
    Sorry I cannot help you out.
  10. #9
    Mar 2015
    1
    I am also looking for a steering stabilizer for my 2003 Escalade AWD 6.0L. I have installed the Cognito idler arm reinforcement kit and Rareparts HD tie rods. Both helped the play considerably. I am looking for a heavier steering feel.
  • You may not post replies
