Rear window/hatch release sticking
Results 1 to 4 of 4
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Rear window/hatch release sticking in Cadillac Escalade Forums; The rear window won't release completely and opening it is difficult when the inside button is pressed, but it works ...
    Partiers_com is offline Cadillac Owners Member
    Feb 2004
    New Castle, PA USA
    44
    64
    UnhappyRear window/hatch release sticking
    The rear window won't release completely and opening it is difficult when the inside button is pressed, but it works fine with the key. Any suggestions?
    Maybe I can take a quick digital picture of my mechanism, if it would help, and someone can let me know what I need to adjust to help it release better. It clicks and releases and the window is slightly ajar, but it is sticking on something unless I use the key.
    Thanks
    Kevin
    '99 Escalade
    99 SKALAID's Avatar
    99 SKALAID is offline Cadillac Owners Fanatic
    Feb 2004
    california
    36
    376
    Re: Rear window/hatch release sticking
    Quote Originally Posted by Partiers_com
    Thanks
    Kevin
    '99 Escalade
    white lithium grease
    i had the same problem with mine, now it works perfectly
    Feb 2004
    New Castle, PA USA
    44
    64
    QuestionRear window/hatch fixed! BUT illumination problem?
    Yes, good advice! The hatch works perfectly now without any other modification to the mechanism. Just some good grease lubrication!
    When you have your headlights on and your dash lights are illuminated, is there a dash light illuminationing the word HATCH for the hatch release or not? :disappoin Mine is completely dark at night. Thanks.
    99 SKALAID's Avatar
    Feb 2004
    california
    36
    376
    Re: Rear window/hatch fixed! BUT illumination problem?
    mine is completely dark also....
  7. Remove Advertisements
