'03 xenon to '02 xenon conversion?
Results 1 to 3 of 3
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, '03 xenon to '02 xenon conversion? in Cadillac Escalade Forums; Anyone know if the '03 factory xenon headlights retrofit to the '02? If so, what parts (e.g., wiring harness, etc.) ...
    slade02 is offline Cadillac Owners Member
    Feb 2004
    Anyone know if the '03 factory xenon headlights retrofit to the '02? If so, what parts (e.g., wiring harness, etc.) are required to do the swap.
    Playdrv4me's Avatar
    Playdrv4me is offline Cadillac Owners 10000+ Posts
    Automobile(s): 1992 STS / 2005 MB G500 / 2003 STS / 2006 XLR-V
    Nov 2003
    TPA / STL / ICT / SAT
    11,694
    Re: '03 xenon to '02 xenon conversion?
    It should work but it wont be cheap. Youll need the lens assembly, Ballast/Ignitor, and Xenon burner (bulb) for each side. In addition, its usually recommended to get a high power wiring harness to handle the additional load of the Xenon headlights at startup. Expect close to 1500.00 for the whole setup if you can get the parts at a reasonable price. Sometimes seller Henrylampa on ebay has factory xenon light assemblies for OEM applications for as low as 250.00 per side and this is tons better and cheaper than trying to buy all the parts at the dealer.
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,289
    You can do it for about a 1/3rd of the price with aftermarket HID parts, the factory in 03' uses the lens as part of the ballast and it goes for about $1500 per side , you can use your lenses and just buy the 9006 HID kit.
