Post Lowering Question
Results 1 to 4 of 4
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Post Lowering Question in Cadillac Escalade Forums; I have a 2003 Escalade with the Ground Force 2/3 kit and 23" Giovanna Attacks. After I had the lowering ...
    jrod178 is offline Cadillac Owners Member
    Apr 2003
    23
    I have a 2003 Escalade with the Ground Force 2/3 kit and 23" Giovanna Attacks. After I had the lowering kit installed the suspension squeaks when going around corners, can become really loud. I called ground force and they said put lithium grease on the parts, anyone else have this problem? If so what did you use to fix it?
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,280
    Re: Post Lowering Question
    I had that problem on a Grand Cherokee I lowered, I have to keep using lithium grease every several weeks to keep the squeaks down
    Apr 2003
    23
    Is there a more permenant way so i dont have to keep doing it, its kind of hard without a lift.
    Apr 2003
    13,280
    If your in an area that does not get that much rain your grease will last much longer in between applications, and a good quality grease like Lubriplate (sp) lasts about the longest I have found.
  7. Remove Advertisements
