Results 1 to 15 of 15
Thread: Door panel Removal
    Oct 2005
    5
    Door panel Removal
    i Just got a 2003 Ext the front speakers seem to go on and off when i go over a bump im thinking the speaker wire is loose is the driver side door panel something can do my self or is it something i should go to the dealer to get done
    T-Dizzy's Avatar
    T-Dizzy is offline Cadillac Owners Fanatic
    Automobile(s): 2003 Escalade EXT, 2014 CTS, 2016 CT6
    Aug 2003
    Massachusetts
    41
    140
    Re: Door panel Removal
    Quote Originally Posted by jreXt
    Two screws hold on the door panel. One under the armrest, and the other one is hidden behind the manual door lock switch. Pop it off with a flathead (careful not to cut the leather) and you'll see the screw. Once both screws are out, just slide the door panel upwards. It is 'hooked' in place by 3 or 4 plastic hangers.
    - Tony
    Jan 2006
    22
    You'll also need to remove the triangle plastic cover that is right above the door panel. It just pulls stright out, with a little force. Then the door panel will lift straight up and out. You'll notice four or five mounting tabs at the bottom of the panel, just set thoes back into the door and let the panel sit there. The speaker clips into the door. Just unclip the speaker and fix your problem.
  5. #4
    urbanski is offline Cadillac Owners 10000+ Posts
    Automobile(s): 05 CTS-V
    Mar 2003
    San 'tone, TX
    23,163
    get some Dynamat in there while you have that panel off
    its totally easy, way easier panel to remove than my Vs
    Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
  6. #5
    Oct 2005
    5
    Thanks for the help fellas got it done found out these are not bose speakers their cheap 20.00 sound logics gonna replace them with jl audio xr650 and the back xr525 anyone have these speakers
  7. #6
    05 Cadillac Escalade's Avatar
    05 Cadillac Escalade is offline Cadillac Owners Connoisseur
    Automobile(s): None - 2007 Range Rover
    Dec 2005
    South Florida
    28
    1,452
    I don't suggest JL Audio. I suggest Treo. A company that is far superior to JL Audio in my opinon. It will cost you a little bit more, but I think it is worth it. Good luck and let us know what you do. Post some pictures of your EXT when you get a chance. Oh yeah, welcome to the forum.
    Thanks.
  8. #7
    Oct 2005
    5
    ok another problem i noticed with these cheap speakers i have to move the wires around for the speaker to work and when i drove and went over a bump speaker would go out so i thought it was a loose wire i bought jl zrs 6.5s and cut wire re did everything and jls dont work at all could it be bad speaker wire any one know
  9. #8
    Mar 2006
    28
    Sounds like the problem to me, but I'm no expert. I would have assumed the same thing.
  10. #9
    Oct 2005
    5
    Quote Originally Posted by Blacklac02
    yea i know it doesnt make sense i guess i try one more time if not ill take it to an audio shop
  11. #10
    Barry ORegan is offline Cadillac Owners Member
    Automobile(s): 2002 Escalade
    Mar 2010
    37
    4
    Will this door panel procedure work with 2002 Escalades?
  12. #11
    superdips's Avatar
    superdips is offline Cadillac Owners Member
    Dec 2007
    56
    Quote Originally Posted by Barry ORegan View Post
    Im wondering the same thing...anyone know???
  13. #12
    sk7's Avatar
    sk7 is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 Escalade AWD
    Nov 2008
    Québec, Canada
    48
    1,025
    Theres one 10mm screw behind the panel where the door open handle is, 2 X 7mm screws one where by the grab handle, the other hiding under the door lock-power window switches panel. Then the complete panel slides up to remove.
  14. #13
    kippjones's Avatar
    kippjones is offline Cadillac Owners Fanatic
    Automobile(s): 2005 ESV & 2008 Escalade
    Apr 2004
    208
    Super easy to remove the door panel. Took less than 5 min.
  15. #14
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Don't forget to remove the black trim peace at the mirror before trying to pull at the panel.
  16. #15
    dcsmithells is offline Cadillac Owners Member
    Automobile(s): 2000 Escalade
    Jun 2016
    59
    1
    Besides the 2 screws in the door pull, there hers on a 2000 Escalade?
  • You may not post replies
