Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac Escalade Forums > Cadillac Escalade, EXT and ESV Forum - 1999 - 2006
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Forum for discussions regarding the First and Second Generation Escalade 2WD, AWD, EXT and ESV.
cadillac-escalade
Cadillac Forums: Correct Tyre Pressures
Old 03-29-06, 07:26 AM
Cadillac(s): 2002 Escalade
View Hetiloak's Photo Album
Casino Cash: $250
Running a set of 23" OZ's and was wondering what correct tyre pressures should be. The are shod with 305-40-23 Toyo Proxes. Ta
  #2 (permalink)
Old 03-29-06, 07:39 PM
Dif Dif is offline
Cadillac Owners Enthusiast
Cadillac(s): 2007 Escalade EXT
View Dif's Photo Album
Casino Cash: $12396
Re: Correct Tyre Pressures
You can find the maximum pressure for the tire ... right on the sidewall of the tire.
I run my tires.. any tires.. at the highest pressure possible before it starts to feel too rough riding.
Unless there is a maximum load in the vehicle when the tires should be pumped to the max...it usually comes down to anywhere from 2-5 pounds below the Maximum pressure stated on the side of the tire.
Experiment a bit.
The only thing you should Not do is run them too low.
  #3 (permalink)
Old 03-29-06, 10:17 PM
Cadillac(s): 2004 Ext (sable black) and 1966 chevelle
View EXTadic's Photo Album
Casino Cash: $585
With your sidewall being 40% of your treadwidth, you could run as low as 35psi. I would keep it closer to 40psi for rim protection. 35 series runs between 45psi and 50psi
  #4 (permalink)
Old 03-30-06, 11:01 AM
jrs05caddyext's Avatar
Cadillac(s): Escalade
View jrs05caddyext's Photo Album
Casino Cash: $7060
I run 45 on 24s.
  #5 (permalink)
Old 04-01-06, 05:47 AM
Casino Cash: $250
Thanks everyone...looks like 38 -40 it will be.
Tags: , ,
correct, pressures, tyre
