O2 Sensor Help needed!
Results 1 to 7 of 7
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, O2 Sensor Help needed! in Cadillac Escalade Forums; I have O2 sensor codes popping and so I need to replace some O2 sensors however I go to the ...
    trodder is offline Cadillac Owners Member
    Automobile(s): Current: 03 Escalade Prev: 01DTS, 98Deville, 89STS, 87Fleet
    Oct 2007
    Minnesota
    72
    I have O2 sensor codes popping and so I need to replace some O2 sensors however I go to the AC Delco website and there is 4 different part numbers. There is only 2 pairs of sensors last i heard so which is which and why a 4th part number? This is for a 2003 Escalade base model 6.0 liter. It appears I need the upstream... what does "POSN 1", "POSN2", and PSON3 designate? I thought it was POSN was maybe position but that doesnt make sense since POSN indicates Upstream and Downstream sensors. If you review all the descriptions carefully, hopefully you will understand my dilemma.
    SENSOR ASM,HTD OXY (POSN 1)
    Part Number: 213-2874
    Product Notes:
    Oxygen Sensor
    Downstream Left,FI, 1 Per Veh
    Downstream Right,FI, 1 Per Veh
    Per Vehicle: 1; Years: 2003-2006
    Part Number: 213-2956
    Product Notes:
    Oxygen Sensor
    Upstream Left,FI, 1 Per Veh
    Upstream Right,FI, 1 Per Veh
    SENSOR,HTD OXY(POSN 2)
    Part Number: 213-1161
    Product Notes:
    Oxygen Sensor
    Center ; IN EXH MANIFOLD/CROSSOVER ; 2 Per Veh
    Per Vehicle: 2; Years: 2003-2006
    SENSOR ASM,HTD OXY (POSN 3)
    Part Number: 213-3867
    Product Notes:
    Oxygen Sensor
    Downstream ; Post converter ; 2 Per Veh
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    I would get the first two
    Oct 2007
    Minnesota
    72
    Re: O2 Sensor Help needed!
    I'm not sure that was entirely helpful. Are there actually 6 O2 sensors? What does POSN mean? Does it mean position? If so what is the relevance? Are the last two part #s just functional equivalents of the first two or vice versa? Can anyone explain further?
    Mar 2011
    speedwell tn,
    11,884
    You have a total of four o2 sensors
    Two on each side
    One towards the manifold (upstream)
    One after the convertor(downstream)
    The other sensors are basically the same thing just different price or the wiring harness is different(universal)
    wesyder's Avatar
    wesyder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,796
    The upstreams are oxygen sensors and the down streams are air fuel ratio sensors, I'm showing both upstreams to be 213-1161 and down streams to be 213-1149 and 213-4670 please double check these i am at the mercy of a parts catalog and no vin#
    Mar 2011
    speedwell tn,
    11,884
    The upstream ones are a bit more pricey then the downstream ones
    I checked on gmpartsdirect
    They show four separate numbers for the sensors(odd but true)
    MuzicMan is offline Cadillac Owners Member
    Automobile(s): 2000 Escalade
    Oct 2010
    Chino, CA
    33
    42
    Amazon has a 15% sale on Bosch sensors, that's one of my favorite places for parts. They have a pretty accurate part finder built in too, just put in your 03 info and it will pop up the sensors that fit.
    Also, if you don't have an alldatadiy.com subscription, it's one of the best investments I've ever made. They have a summer special going on now for $9.95/one year of access per vehicle. Promo Code is DIY2014 They would definitely have detailed info on exactly what sensors are on the truck.
    Just a thought from that list in your first post, I bet that is showing for both the 5.3L and the 6.0L engines maybe? You should need just one set of POSN1 and one set of POSN2
  10. Remove Advertisements
