Australian EXT suffers notorious symptoms!
Results 1 to 8 of 8
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Australian EXT suffers notorious symptoms! in Cadillac Escalade Forums; Well after searching and searching I think I'm going to reach out for some help. 04 Ext, only black 04 ...
    blackescalade79 is offline Cadillac Owners Member
    Automobile(s): escalade
    Jul 2011
    9
    04 Ext, only black 04 in Australia. No Cadillac dealerships here...
    I've read many posts in regards to the voltage drop issues whilst the engine is running , however my trucks issue begins prior to the engine starting.
    So key in, turn to Acc: full power - cad logo on screen.
    One more click over to Ignition: all hell breaks loose, dome lights flicker as well as exterior lights, the screen resets, flickers and displays the Delphi version.
    When I proceed to start: I get nothing but the clicks so I stop. Try again and the next crank evolves into the first turn, then a faster turn. It speeds up when I repeat the process and will start as if there was never a problem.
    This is however only in the morning/after approx 12 hrs and I do believe whatever is causing the issue needs some heat in order to get going.
    Have checked and replaced the ground straps.
    Installed a new battery, contacts are good - the only thing I can think to do is reflash the ecu?
    Your feedback/insight much apreesh as always!
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    I would say that starter motor is failing
    I had this happen in my previous car and it was a gamble as to when it may start next
    Got me in the driveway(thank god) and it decided no go(just peachy as it was the day I had set to take it in) I sat there and worked the key at least 100 times before it cranked over
    That little slice of hell happened over three months
    I replaced the starter and it would crank first try(though I didn't keep it long after that due to other issues)
    Jul 2011
    9
    Interesting.... This EXT has just clicked over 120,000kms, I guess it's done it's duty. Makes so much sense though.
    3months - exactly the same duration. I did however enjoy a couple of moments of satisfaction though when I'd start this procedure in public when the spiteful guy walking passed was ever so happy to say,
    "mate she's dead, that ain't starting!'.
    So I smiled and asked him if he had read Steven King's first story, and he heard the opposite of a dying truck. ;-)
    Might pull the starter out of the h2, I'm guessing it'd be same? - Oh, and thank you!
    Mar 2011
    speedwell tn,
    11,884
    Ha ha I got a kick out of that
    The starter in the hummer is that same as long as your escalade has the 6.0(I don't know if the smaller engine uses the same starter but could be wrong)
    I know the feeling though I had people give me funny looks the day my car did this in a Walmart parking lot(very embarrassing) some said I should have junked the car(last Chrysler I have owned)
    The starter isn't hard to swap its just tricky to get to
    I love the hummer h2 my dad has one and me and him both love to drive it
    Glad to help
    Jul 2011
    9
    Yeh, the h2 is actually a stretch and even though I'd like to put the escalade one back in there, I can't afford to have it sporadically play up during a wedding etc.
    I'll change them out tomorrow and maybe shoot some pics of them both.
    Mar 2011
    speedwell tn,
    11,884
    Ah cool
    I have seen the strech hummer limos but never have been in one
    I suggest just trying and is if it works then buy a new starter
    Jul 2011
    9
    just about to commence that now. One thing that still baffles me though... Fair enough the starter motor appears to be creating resistance for a free flow crank, but switching the key from ACC - seeing full power in all interior electrics, to ON/IGNITION - suddenly having everything flickering.
    Seems as if the IGNITION position is deprived of full power.
    Mar 2011
    speedwell tn,
    11,884
    That's how mine did when the starter failed
    If the starter from the hummer doesn't work then you may have other issues but I'd say more then likely its the starter bad
  11. Remove Advertisements
