2000 Escalade - 4WD question
Results 1 to 4 of 4
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 2000 Escalade - 4WD question in Cadillac Escalade Forums; I have a question with how the 4WD works on my 2000 Escalade. Shockingly..LOL...I don't engage the 4WD option too ...
    MuzicMan is offline Cadillac Owners Member
    Automobile(s): 2000 Escalade
    Oct 2010
    Chino, CA
    32
    42
    I have a question with how the 4WD works on my 2000 Escalade. Shockingly..LOL...I don't engage the 4WD option too often, but when I do, it works fine except for making hard turns. It binds up basically, doesn't want to keep rolling. Is this the front U-joints?
    Is this a normal thing or is something wrong? I'm a 4WD novice and would appreciate any help.
    wesyder's Avatar
    wesyder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,792
    That is normal on tight turns, the wheels are trying to rotate the same speed however on a turn the inner wheel on the turn is gonna be a different speed than the outer and that is where the binding occurs
    Oct 2010
    Chino, CA
    32
    42
    Re: 2000 Escalade - 4WD question
    Ah I see, so the front differential doesn't work like the rear one? When I put it into Auto mode, it turns fine. So does that mean in Auto mode, the front wheels are not locked I'm assuming?
    I basically only use Auto mode in rainy wet weather, and only enage 4Hi very rarely. My mechanic said it's a good idea to engage 4Hi just for a little bit to keep all the fluids moving and happy. Is that BS? We're talking like once a year, maybe twice.
  5. #4
    wesyder's Avatar
    Mar 2009
    Eastvale Calif
    1,792
    They are similar but the rear wheels don't steer so the speed in which they rotate is not that big of a difference so you don't get the binding in 2wd unless there was a diff locker added, no your mechanics advice wont be a problem, the auto kicks in when a wheel slips from lack of traction
  6. Remove Advertisements
