2000 Escalade - Erratic window washer
Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By the cadillac man
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 2000 Escalade - Erratic window washer in Cadillac Escalade Forums; My window washers have been working erratically, usually not spraying at all but wipers work fine, making a god awful ...
    MuzicMan is offline Cadillac Owners Member
    Automobile(s): 2000 Escalade
    Oct 2010
    Chino, CA
    33
    42
    My window washers have been working erratically, usually not spraying at all but wipers work fine, making a god awful mess when I need to see better LOL!
    I've already had the pump replaced and wires checked there, and still have this issue. Could this be the control wand?
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Can you hear the pump when the washer fluid should be sprayed on the windshield?
    If no then the pump is bad
    There is two one for front one for rear
    Oct 2010
    Chino, CA
    33
    42
    Re: 2000 Escalade - Erratic window washer
    Nope, no sound when at all when I press the washer trigger on the wand except for that of the wipers. This new pump is less than a year old. Would it die that quickly? Rear window is fine.
    Mar 2011
    speedwell tn,
    11,884
    Could be possible the harness worked loose
    If not then the pump has failed
    MuzicMan likes this.
  7. Remove Advertisements
