traction active
Results 1 to 9 of 9
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, traction active in Cadillac Escalade Forums; My truck keeps on showing traction active and it slows down everytine that happens. Please help I changed front and ...
    rubio05 is offline Cadillac Owners Member
    Aug 2014
    traction active
    My truck keeps on showing traction active and it slows down everytine that happens. Please help I changed front and back abs sensors.
    wesyder's Avatar
    wesyder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,814
    Quote Originally Posted by rubio05
    your going to have to have it scanned to see what the problem is
    Aug 2014
    Sorry I forgot to ask. My obd port is not working either any ideas what it could be?
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Check the power outlets for coins and replace the cigar fuse
    bigsc is offline Cadillac Owners Member
    Automobile(s): 2006 Escalade ESV Platinum
    May 2013
    4
    Re: traction active
    I am having the same issue. I changed my rear brake pads and the Traction control stopped coming on but I am still having the initial slow response then It will take off. The message center will display "service ride control" then the ABS light and the T/C light will come on. If they stay on, the vehicle will perform normally. If they go out, the vehicle will accelerate slow from taking off at a traffic light or a stop in traffic. What in the world could cause this? And why would the idiots at GM allow something like this to happen where it could possibly cause seriuos injury or death in heavy traffic. I have had a t least three occasions where i was narrowly missed by a tractor and trailer. Can someone point me in the right direction a to what to replace or where to look to correct the problem.
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by bigsc
    Likely a wheel speed sensor but the codes needs to be pulled to be sure
    I would also check for firmware updates for the ebcm as mine would do random service traction control messages and the system would engage at slow speeds if I am turning onto my road(not fun)
    After I had the ebcm updated it never has done it
    dahubby98's Avatar
    dahubby98 is offline Cadillac Owners Member
    Automobile(s): escalade ext
    Sep 2013
    Missouri
    61
    I just had the same problem. My traction system disabled, check engine lightbwould come on and my truck wouldn't go past 35 mph. I had to replace the tps and the wiring harness attached to it. It fixed the issue . There was a code that i has also, u think it was P1125. You would need the OBD2 working to get it though
    May 2013
    4
    Re: traction active
    Thanks Cadillac Man.
    Mar 2011
    speedwell tn,
    11,884
    Glad to help
    Let me know if that doesn't fix the issue
  12. Remove Advertisements
