2006 Escalade- transmission question
Results 1 to 10 of 10
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 2006 Escalade- transmission question in Cadillac Escalade Forums; Our 2006 Escalade check engine light came on, code read "vacuum leak", We have had the problem with the gas ...
    GLewis is offline Cadillac Owners Member
    Jul 2014
    6
    Our 2006 Escalade check engine light came on, code read "vacuum leak", We have had the problem with the gas cap before and had replaced it, so I didn't think much of it. While on the highway the other day, at speeds of 60 - 70, the transmission kept switching in and out of overdrive.
    Is there a Vacuum switch for the overdrive of the transmission, or am I looking at bigger problems?
    Thanks in advance
    Codes are p0449, p0455, p0442
    BIG-KO is offline Cadillac Owners Fanatic
    Automobile(s): 2003 escalade
    Mar 2014
    CHAMBERSBURG,PA
    50
    104
    Re: 2006 Escalade- transmission question
    Can you post what the code number is. There is no vacuum sensor on the trans. All the shifting is done by electric solenoids controlled by the engine computer, the PCM.
    Jul 2014
    6
    Codes are posted above, all point to evap system, purchased new solenoid , now to try and find it to replace it?
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by GLewis
    Top of the fuel tank towards the front
    Jul 2014
    6
    Thanks
    Jul 2014
    6
    Replaced solenoid (was on top of engine towards front, not in front of tank), seems to run OK, but check engine light did not go out, do I need to reset it? If so how?
    Mar 2011
    speedwell tn,
    11,884
    Its on because there is still a fault in the system somewhere
    See what codes it is and report back
    wesyder's Avatar
    wesyder is online now Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,807
    your gonna need to clear it if you have done a repair it wont go out on its own until the obd system runs that particular test again and thats only if the problem was fixed, you can clear it with a scanner or disconnect the battery for a few minutes
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by wesyder
    I have never had to clear the codes to turn off the check engine light after replacing any bad part
    The PCM runs tests on almost everything at start up(the o2 sensors are tested after they warm up unless the heater circuit is bad)
    wesyder's Avatar
    Mar 2009
    Eastvale Calif
    1,807
    Quote Originally Posted by the cadillac man
    I have never had to clear the codes to turn off the check engine light after replacing any bad part The PCM runs tests on almost everything at start up(the o2 sensors are tested after they warm up unless the heater circuit is bad)
    for the o2 sensors you are correct however they actually don't need to wait till warm up they just need to complete the circuit from 12v and back to the computer, other emission components related to evap are not tested right away the vehicle needs to be driven, evap is actually the hardest monitor to pass when performing a smog inspection cuz u really don't know when its gonna self test, some manuals offer driving instructions to expedite this process.. although some states don't require smog inspections the vehicles are alike
  13. Remove Advertisements
