Odd thumping noise from inside rear compartment???
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Odd thumping noise from inside rear compartment??? in Cadillac Escalade Forums; Noticed a very faint and repetitive thumping noise coming from inside the escalade today. With engine running and parked (isn't ...
    biffrogers is offline Cadillac Owners Member
    Automobile(s): 2005 Escalade
    Jul 2014
    Damascus, OR
    14
    With engine running and parked (isn't a driving issue), there's a VERY faint thumping coming from underneath the passenger side plastic cover above the rear wheel well.
    Haven't had a chance to pull the cover just yet...wondering if anyone might know or have had same scenario?
    Can't hear it from outside...fwiw.
    Thoughts?
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Does it sound like a helicopter is above you?
    If yes it is likely a wheel bearing(been through that and it almost drove me nuts with my previous car)
    Jul 2014
    Damascus, OR
    14
    Re: Odd thumping noise from inside rear compartment???
    Nope...it's making a faint noise while the car is static...I imagine I'll have to tear into the cover to investigate further.
    Mar 2011
    speedwell tn,
    11,884
    Does it do this with the ac on?
    Retrax's Avatar
    Retrax is offline Cadillac Owners Fanatic
    Automobile(s): 2012 CTS-V, 2003 Escalade EXT
    Jul 2013
    Saint Paul, MN
    257
    I had this happen in a car once. It drove me nuts until I finally found out a hose was vibrating against the firewall sometimes. Check everything under the hood such as wire looms, hoses, components, etc. Look along the firewall and inner wheel wells. Sound can travel and it can be difficult to pinpoint the origin.
    Jul 2014
    Damascus, OR
    14
    I'll have to check...not sure if it was AC related. Sadly I can't check it until I figure out if my starter is bad. Was late to a friend's wedding today when the rig wouldn't start. Turned the key and nothing, nada. Need to check battery voltage (recently replaced alternator) but am pretty sure it's either the NSS or starter. Wow...I hope my luck improves with this caddy soon. Has been one thing after another...
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by biffrogers
    Does the relay click in the under hood fuse box??
    Jul 2014
    Damascus, OR
    14
    Hard to hear but I think the relay does click. Maybe it's a starter, battery and ignition issue all together? Caddy wouldn't start the other day...so I left the battery on a trickle charger until I got home from work. Started the rig in the evening and drove it 100 miles with no issues. Battery volt meter did show JUST under 14 volts which should be higher. Alternator is brand spankin new...was charging well above 14 until the last few days.
    So...I left the trickle charger on all night...started the rig this morning and fired up. Turned it off (took 15 minutes to load the kids in the car, etc). Won't start now.
    Dash lights seem to be bright and lights work...but didn't have time to test battery voltage (will check tonight). Possible battery didn't have enough juice to start. I have a gut feeling that the ignition switch is also to blame. The battery has had a hard life...wouldn't be surprised if it's on the verge of dying.
    Thoughts? Other than checking battery voltage...not sure where else to start? No codes that I can see other than cat efficiency code.
    Sheesh...I can explore the thumping noise at another time...haha. Having the caddy start would ne nice...
    Mar 2011
    speedwell tn,
    11,884
    Have the battery load tested at a parts place
    It is possible its developing a bad cell(had it happen to me before) causing it to drain and be weak
    Nice Ride is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 ESV Platinum / 2013 SRX Premium
    Jan 2012
    1,245
    Uh, was this car used in the Move Good Fellas
    Jul 2014
    Damascus, OR
    14
    Nope wasn't a movie car .
    So...replaced the previous battery last night with interstate batt. (old battery had too much voltage drop when compressor kicked on for rear susp.).
    Engine still won't crank with new battery (all instrumentation and lights appear to be functioning normally). Good contacts with terminals, etc.
    Tried moving the key around in the ignition...no dice.
    Thinking it has to be a starter at this point and perhaps combo ignition issue? Have checked fuses multiple times...guess it's time to check again.
    Debating about pulling the starter to have it tested, etc. Thoughts?
    Mar 2011
    speedwell tn,
    11,884
    Before you pull the starter try swapping around the relays
    Jul 2014
    Damascus, OR
    14
    Did that...pulled the relay and swapped. No change...
  16. #14
    Mar 2011
    speedwell tn,
    11,884
    Then the starter has failed
    Mine did this and I had to get my uncle to drive me home then came back the next day with a haul back for it
  17. #15
    Retrax's Avatar
    Jul 2013
    Saint Paul, MN
    257
    It could just be the solenoid for the starter. Often times the solenoid gets weak and the plunger gets stuck. Climb under there and tap on it with a hammer to see if the plunger will free up. You might get lucky and only need a new solenoid instead of the whole starter. I haven't looked at the escalade's but the typical gm starters have the solenoid mounted right on the starter where it gets cooked with engine and exhaust heat.
    After the solenoid cooked on my 67 Camaro I used a remote mount Ford solenoid mounted on the firewall to keep it away from heat and bypassed the starter mounted one. I never had another problem. The gm solenoid mount design is kind of a weak link because of this. I can't tell you if this could possibly damage the electronics in your car but we used to use a screw driver to jump the terminals on the solenoid/starter on old cars. If the starter cranked, we new the solenoid was bad.
  18. Remove Advertisements
