Odd thumping noise from inside rear compartment??? - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Odd thumping noise from inside rear compartment??? in Cadillac Escalade Forums; Originally Posted by Retrax It could just be the solenoid for the starter. Often times the solenoid gets weak and ...
  1. #16
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Retrax
    It could just be the solenoid for the starter. Often times the solenoid gets weak and the plunger gets stuck. Climb under there and tap on it with a hammer to see if the plunger will free up. You might get lucky and only need a new solenoid instead of the whole starter. I haven't looked at the escalade's but the typical gm starters have the solenoid mounted right on the starter where it gets cooked with engine and exhaust heat. After the solenoid cooked on my 67 Camaro I used a remote mount Ford solenoid mounted on the firewall to keep it away from heat and bypassed the starter mounted one. I never had another problem. The gm solenoid mount design is kind of a weak link because of this. I can't tell you if this could possibly damage the electronics in your car but we used to use a screw driver to jump the terminals on the solenoid/starter on old cars. If the starter cranked, we new the solenoid was bad.
    I had a guy do that trick on my cordoba once
    What we didn't know was the starter was in a bind(man that was a sticky spot I hope I am never in again)
  2. #17
    biffrogers is offline Cadillac Owners Member
    Automobile(s): 2005 Escalade
    Jul 2014
    Damascus, OR
    14
    Re: Odd thumping noise from inside rear compartment???
    Good to know...will keep investigating. Haven't given up just yet. Thanks for the all advice!
  3. Remove Advertisements
