02 6.0 escalade rough idle hesitation
Results 1 to 10 of 10
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 02 6.0 escalade rough idle hesitation in Cadillac Escalade Forums; I have an 02 escalade 6.0 awd.. started with a moderate hesitation and rough idle. Replaced plugs wires cleaned maf ...
    dsm1973 is offline Cadillac Owners Member
    Jul 2014
    4
    I have an 02 escalade 6.0 awd.. started with a moderate hesitation and rough idle. Replaced plugs wires cleaned maf put lucas fuel injector cleaner in... everything done made a considerable difference but still ideling rough to where it almost stalls at times and a mild hesitation now.looked for vacume leak couldnt find anything. It is throwing codes po101 and po430 any help would be appreciated thank you
    Sent from AutoGuide.com Free App
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    P0101 is for the mass air flow sensor
    P0430 means catalyst system low efficiency bank 2
    Replace the mass air flow sensor(if using a k&n air filter swap it out for oem) that will fix the first code
    The second code is likely for the catalytic convertor(likely plugged or bad)
    Jul 2014
    4
    Re: 02 6.0 escalade rough idle hesitation
    Thank you for the input... That was the direction was heading in was hopeing may have been just an 02 sensor though alot cheeper .. But have an appt thur to have 2 new converters installed.
    Mar 2011
    speedwell tn,
    11,884
    Ok let me know how it turns out
    Jul 2014
    4
    Didnt replace the converters I gutted them and welded them back up. After that I put anti foulers on the down stream 02 sensors. took it for a test drive and the truck sounds amazing and is back to the power that it shuould have... thank you for your help
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by dsm1973
    Didnt replace the converters I gutted them and welded them back up. After that I put anti foulers on the down stream 02 sensors. took it for a test drive and the truck sounds amazing and is back to the power that it shuould have... thank you for your help Sent from AutoGuide.com Free App
    Curious where you got the anti foulers?
    I think I may have this done if mine starts doing like this
    Glad to hear you got it fixed
    wesyder's Avatar
    wesyder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,796
    Quote Originally Posted by the cadillac man
    Curious where you got the anti foulers? I think I may have this done if mine starts doing like this Glad to hear you got it fixed
    the anti foulers can be picked up at the auto parts store
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by wesyder
    Ok thanks
    Jul 2014
    4
    The anti foulers it takes 4 of them. drill 2 of them out so that your 02 sensor fits in to it I used a 9/16 drill. Screw the o2 sensor into the drilled out anti fouler and screw that into the antifouler thats not drilled out and install in your down pipe. Worked like a charm no issues with any check engine lights yet
    Mar 2011
    speedwell tn,
    11,884
    The anti foulers it takes 4 of them. drill 2 of them out so that your 02 sensor fits in to it I used a 9/16 drill. Screw the o2 sensor into the drilled out anti fouler and screw that into the antifouler thats not drilled out and install in your down pipe. Worked like a charm no issues with any check engine lights yet Sent from AutoGuide.com Free App
    Thanks I will keep this info on my phone for the day I need to do this
  13. Remove Advertisements
