Aftermarket Radio horrible reception
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Aftermarket Radio horrible reception in Cadillac Escalade Forums; I just installed a Pioneer AVH-X5600BHS in my 03 EXT and the radio reception is terrible. There are 2 radio ...
    Jim1761 is offline Cadillac Owners Member
    Automobile(s): 2003 Escalade EXT
    Dec 2012
    24
    I just installed a Pioneer AVH-X5600BHS in my 03 EXT and the radio reception is terrible. There are 2 radio stations within 12 miles of me and they don't even come in clear. I replaced the factory Nav and that worked fine. I recently sold another 03 with a Pioneer AVH-5600bt in it and it was the same, terrible reception, only had the truck a month before selling it and never looked into the problem. Has anyone run into this before if so how did you fix it?
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Was the power antenna wire connected?
    I had a car that did like this and it was the power antenna wire
    After I connected it the radio worked great
    caprice man 76's Avatar
    caprice man 76 is offline Cadillac Owners Fanatic
    Automobile(s): ESCALADE ESV PLATINUM
    Jan 2014
    SAN JOSE.CALIF
    53
    186
    Re: Aftermarket Radio horrible reception
    I have the same problem I installed a kw-nt700 in my truck to replace the og radio nav unit with same result you are talking about. I have to listen the ipod function almost all of the time.
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by caprice man 76
    Read my post just above yours I think it will help
    I love having the iPod in the truck as it makes road trips more enjoyable (haven't got my sat radio tuner installed yet)
    Dec 2012
    24
    From what I am told there is no power anttenna wire in the harness, the radio has it but I don't think the truck does. If you know different please share cause it's driving me nuts.
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Jim1761
    Your thinking of the base and mid line radios this don't have the antenna amp like the premium radios do
    The premium radios all have it
    Its close to the power in my wiring diagrams and is dark green in color
    There is also a red wire from the antenna amp don't use that as damage to your radio can happen
    Dec 2012
    24
    By any chance do you have a picture of the diagram? I have the Pac Audio RP5-GM11 plugged into the harness, there is one blue wire coming out that they state to not use, they were the ones that told there was no antenna amp in my vehicle
    Mar 2011
    speedwell tn,
    11,884
    They likely thought you didn't have the premium radio package
    Let me look up the install manual for that interface and see what wire goes to what
    Found the manual but it didn't show a pic of the wiring diagram below is a link showing the pinout of the radio harness
    http://crutchfield.custhelp.com/app/...b0FtWWFrTGs%3D
    The power antenna is pin 15 and is dark green in the main harness
    They likely think that the Tahoe and escalade use the same radio(they don't) the escalade has a power antenna booster due to the antennas being in the side windows
    Dec 2012
    24
    Are you sure about this? My truck has a fender mounted antenna
    Jan 2014
    SAN JOSE.CALIF
    53
    186
    I have never seen a escalade with a fender mounted antenna. I have seen them with stick on old school cell phone antenna on the side rear quarter window.a lot of tahoe's and yukon's with stick on antenna's but I don't know what their for.
    Mar 2011
    speedwell tn,
    11,884
    The ext does have a fender mounted whip antenna
    The suv models have the antenna in the rear side windows
    The ext's do
    the old school cell phone antenna is for the older onstar system(analog only) my mom's 02 has one
    03 up has it on the roof
    Also(I forgot to add it) the first gen body style escalades have the whip antenna
    The 03 up models with it in the rear windows do have a antenna booster which does have a turn on feed from the radio
    Tahoe's don't have it as they have the base radio(non lux non Bose)
    Certain models with the mid line radio don't have it
    Just the premium radios (there is two versions but the wiring is the same)has the antenna power feed in the main harness due to two antennas in the rear windows
    Dec 2012
    24
    I do have an EXT, I stated that in my original post and they all have the fender mounted antenna only, does an EXT have an antenna amp wire?
    Mar 2011
    speedwell tn,
    11,884
    It is possible but unlikely
    I know my dad's h2 has the premium radio and it has a stubby antenna on the roof so I know it has to have the booster
    Check the wiring diagram in the link I posted and if the wiring matches then it has it(my gm service manual shows the premium radios with a antenna power feed)
    Gm could have put it in both pick up and suv body styles just used a different antenna(never tore into a ext to verify though)
  16. #14
    Dec 2012
    24
    Will do, greatly appreciate all the help
  17. #15
    Mar 2011
    speedwell tn,
    11,884
    Let me know how it turns out
  18. Remove Advertisements
