Right tail light not lighting up when driving lights are engaged
Results 1 to 14 of 14
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Right tail light not lighting up when driving lights are engaged in Cadillac Escalade Forums; 2005 ESV My right tail light does not light up when I put my driving lights on. However when I ...
    geoprz is offline Cadillac Owners Member
    Automobile(s): Deville, Escalade ESV
    Mar 2013
    27
    2005 ESV
    My right tail light does not light up when I put my driving lights on. However when I apply the brakes they light up and turn signals work. Changed all the bulbs. Also I replaced the "block" which the harnesses connect to. Still doesn't work.
    I'm lost and frustrated. Can someone please help...
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Has the bulbs been replaced?
    Mar 2013
    27
    Re: Right tail light not lighting up when driving lights are engaged
    Yes they have.
  5. #4
    flyingdutchman is offline Cadillac Owners Fanatic
    Oct 2004
    340
    Quote Originally Posted by the cadillac man View Post
    Based on "READING" the OP post, I have come to the conclusion that they were
  6. #5
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by flyingdutchman
    My mistake I didn't have my caffeine before I read it
    ---------- Check for voltage its possible its a blown fuse
  7. #6
    Mar 2013
    27
    Checked all fuses also
  8. #7
    Mar 2011
    speedwell tn,
    11,884
    Is the right rear park lamp fuse blown?(its a 10amp fuse in the under hood fuse box labeled rr park)
    Both rear lights have a separate fuse for the running light circuit
  9. #8
    Mar 2013
    27
    I checked that fuse also. It is not blown.
    Can it be a failed tail light wire harness? The whole electrical system was clean, not damaged, all plugs were mint
  10. #9
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by geoprz
    I checked that fuse also. It is not blown. Can it be a failed tail light wire harness? The whole electrical system was clean, not damaged, all plugs were mint
    I wonder if its a bad ground for that harness
    I will look at my service manual and find the ground point and get back to you
  11. #10
    Mar 2011
    speedwell tn,
    11,884
    Update
    After looking at my service manual it looks like all the lights have one ground so it must be a bad harness
  12. #11
    Mar 2013
    27
    Thank you for doing that!
    I also forgot to mention that my license plate lights do not work also,,,
  13. #12
    Mar 2011
    speedwell tn,
    11,884
    Thank you for doing that! I also forgot to mention that my license plate lights do not work also,,,
    Ok I will have to check more but its likely a bad ground since all of the rear lighting is on one ground
    I will look up the ground point and update you where its at
  14. #13
    Mar 2013
    27
    Could you tell me the part number for just the wiring harness that goes from the block to the right rear tail light?
    I was at the dealership and they couldn't find it. Apparently I have to buy the whole rear wiring harness
  15. #14
    Mar 2011
    speedwell tn,
    11,884
    Could you tell me the part number for just the wiring harness that goes from the block to the right rear tail light? I was at the dealership and they couldn't find it. Apparently I have to buy the whole rear wiring harness
    Its a whole part and not two parts
    It works both sides
  16. Remove Advertisements
