ECM/PCM on 2006 Escalade
Results 1 to 13 of 13
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, ECM/PCM on 2006 Escalade in Cadillac Escalade Forums; Has anyone ever changed the PCM in their truck? Any pointers to do the job would be great...
    joeyb418 is offline Cadillac Owners Member
    Automobile(s): None
    May 2014
    None
    23
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Its not hard to do just make sure you disconnect the battery cables
    Automobile(s): None
    May 2014
    None
    23
    Ok thanks
    Mar 2011
    speedwell tn,
    11,884
    Also remember the PCM has the vin number encoded in the software(if the bcm doesn't see the correct vin the truck won't start)
    Automobile(s): None
    May 2014
    None
    23
    Yes I was told that by the company I got the pcm from which I thought might have something to do with my tranny problems I've been having but it's still giving me problems. It's very odd to me that the rebuilt tranny I bought gives me the same exact problems as the previous tranny , I'm running out of ideas . Don't know what to do next? Tranny still has a 2-3 flair up when it shifts. Guess I'm going to have to contact AME transmissions and see what they suggest
    Mar 2011
    speedwell tn,
    11,884
    Its possible given that the PCM works the tranny
    Automobile(s): None
    May 2014
    None
    23
    Still no change even after I put the new PCM in the truck . Any other ideas of what could make the rebuilt tranny shift exactly how my old failing trans was shifting?? I could understand if the rebuilt had some issues but to do the same exact thing as the old trans is mind boggling almost like it's something other than the trans which I thought would be the PCM
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by joeyb418
    I would check the wiring harnesses between the PCM and the tranny
    Automobile(s): None
    May 2014
    None
    23
    What about a valve body shift kit? Another suggestion I was given is to get a Sonnax boost valve but I would have to drop the trans to get to the pump for that right?
    Mar 2011
    speedwell tn,
    11,884
    There has been a few other members who have got the shift kit and had great results
    You would have to drop the tranny to gain access to the pump
    Automobile(s): None
    May 2014
    None
    23
    Do you know what voltage I should have at the TPS during idle? Could a faulty TPS effect the way the truck shifts?
    Mar 2011
    speedwell tn,
    11,884
    I will have to check my service manual to see
    But a bad tps will cause issues like this
    Automobile(s): None
    May 2014
    None
    23
    Ok let me know there are no codes or check engine light in the truck but I figured it's not a bad idea to go over it anyway
  16. Remove Advertisements
