2003 escalade ext fluid leaking from right side engine compartment
Results 1 to 7 of 7
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 2003 escalade ext fluid leaking from right side engine compartment in Cadillac Escalade Forums; I have a 2003 escalade ext and found a leak coming from the passenger side engine compartment, is it coming ...
    lyman is offline Cadillac Owners Member
    Jun 2014
    I have a 2003 escalade ext and found a leak coming from the passenger side engine compartment, is it coming from my rack and pinion. Any help would be greatly appreciated.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Is it colored or clear?
    Does it only do it with the a/c on?
    I ask as when the a/c is on it will create water which is normal
    Jun 2014
    Re: 2003 escalade ext fluid leaking from right side engine compartment
    its not condensation from a/c. it is colored and is oily to touch.
    it kinda smells like power steering fluid.
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by lyman
    its not condensation from a/c. it is colored and is oily to touch. ---------- it kinda smells like power steering fluid.
    What color?
    The power steering would be towards the front drivers side
    Retrax's Avatar
    Retrax is offline Cadillac Owners Fanatic
    Automobile(s): 2012 CTS-V, 2003 Escalade EXT
    Jul 2013
    Saint Paul, MN
    257
    This may sound strange but if you had an oil change recently and they greased the chassis, it could be from that as well. If it is not power steering fluid, see if it is liquified chassis grease. Put down a fresh piece of cardboard or newspaper to help you locate the source.
    Retrax's Avatar
    Jul 2013
    Saint Paul, MN
    257
    So, what did you find?
    Mar 2011
    speedwell tn,
    11,884
    Also curious any updates?
  10. Remove Advertisements
