2002 EXT Driver side window
Results 1 to 4 of 4
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 2002 EXT Driver side window in Cadillac Escalade Forums; My driver window once in a while (not every time) will only go down but will not roll back up, ...
    gevinsky is offline Cadillac Owners Member
    Automobile(s): Escalade EXT- ( STX Sedan)
    Aug 2013
    83
    4
    Unhappy2002 EXT Driver side window
    My driver window once in a while (not every time) will only go down but will not roll back up, open & slam door sometimes will work. sometime leave it set for 1/2 hr or so rolls right up. Just went out & tried to make it do it ,but worked every time. Not good in state of WA. where it rains, could it be a bad ground if so how toe fix,Maybe a bad connection in push button switch. HELP
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Sounds like the motor drawing too much current and kicking out the circuit breaker
    Aug 2013
    83
    4
    Re: 2002 EXT Driver side window
    If the circuit breaker was kicked out it would stop going down also (wouldn't it)? I can roll window down 1/2 way & will not go back up but will still go down
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by gevinsky
    If the breaker kicked out it would temporary kill all window control
    It sounds like the control
  7. Remove Advertisements
